Feature Requests
VMIX PLAYLIST import video from DATASOURCE
Joined: 3/15/2018(UTC) Posts: 82  Thanks: 5 times Was thanked: 10 time(s) in 8 post(s)
Hello , We need the feature , it will make life so easy , and it will make VMIX BOOOOOOOOOOOOOOOOOOOOOOOOOOOM A PLAYLIST in vmix can load videos from DATA SOURCE , and also can read video order from datasource , this will make everything easy , and will make vmix complete automation so we have lot of videos , regularly we need to add or remove video from playlist , also video play order , the playlist will read the datasource and update automatically here is some caps of what data should be marcyaghi1 attached the following image(s):  or1.PNG (15kb) downloaded 70 time(s). datasource.PNG (42kb) downloaded 77 time(s).You cannot view/download attachments. Try to login or register.
Marc
by default vMix can use M3U8 playlist files inside a List input.
If all your video files are already stored in a database, you can very easily create a script to build a M3U8 file on the fly with all sorting or ordering options you desire in no time. And you can even script the creation of the List input in vMix dynamically.
I'm pretty sure you can even create a shortcut in vMix that will start the execution of this script.
Bien à toi Guillaume
Hello Dwan I talked to Martin yesterday during the VMIX LIVE SHOW , they said to put it in feature request , as this option is not like M3u files , its a live datasource for video playlist hope you know what i mean , its different automation
Regards
I'm not saying this FR is irrelevant. Just trying to help as vMix already offers solutions for dynamic playlists
Vmix will also be the most dynamic software if also beside video-playlist data source , if we add also image data source , or image list from data source
it will help us a lot in news production
thanks all
Quote: it will make VMIX BOOOOOOOOOOOOOOOOOOOOOOOOOOOM Vmix will also be the most dynamic software
Why do you keep implying vMix isn't dynamic, flexible etc ? With a little effort it would be easy enough to create your own requests ? Whatever vMix is capable of out of the box there will always be something that will not "satisfy" a personal need On the other hand the tools available in vMix allows one to create ones own specific needs Would it be handy to have image list datasource? maybe. realy a shortcomming? don't believe so As an example Say you want to display a national flag next to someones name retrieved from a datasource Have the datasource containing the country code , have a folder with all national flags named with the same country codes Have some code in your title that puls/displays the correct flag based on the code , presto (and who says that would only work for flags ;-) ) Be creative
Quote: image list from data source I have done that many times. It just works great...
please guys we need your vote here , if anyone interested in this feature please add a +1
thanks a lot
Joined: 9/30/2016(UTC) Posts: 5  Location: Ukraine, Ternopil
please consider this feature
Joined: 3/8/2016(UTC) Posts: 123 Location: Anniston, Alabama
+1, and include LIST input as well
Joined: 4/22/2016(UTC) Posts: 83   Location: UK Thanks: 18 times Was thanked: 17 time(s) in 14 post(s)
+1 to data sources as a source for a list input. This would enable the playout operator to be located anywhere in the world - and simply be able to update a google sheet to edit the list. Very simple to use - nice idea!
 1 user thanked StepBackInTime_TV for this useful post.
Thanks: 211 times Was thanked: 13 time(s) in 12 post(s)
Thanks: 38 times Was thanked: 24 time(s) in 20 post(s)
+1! Also it can be usefull for me. Thanks!
please consider this next update
Joined: 4/11/2020(UTC) Posts: 3  Location: HCM Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: marcyaghi1  Hello , We need the feature , it will make life so easy , and it will make VMIX BOOOOOOOOOOOOOOOOOOOOOOOOOOOM
hello, after 3 years, did we have this feature? plz update
 1 user thanked NguyenLion for this useful post.
Feature Requests
