userr777
#1 Posted : Thursday, May 10, 2018 7:29:31 AM(UTC)
userr777
The web browser input is so slow that for me it's really unusable. It takes about 5 minutes to fully load a web page Ex: vmix.com
All the apss use NVIDIA graphics(GeForce GTX 1050 Ti). Chrome is default browser. Any help please?
#2 Posted : Thursday, May 10, 2018 11:19:06 AM(UTC)
Was thanked: 795 time(s) in 589 post(s)
Do you have enough bandwidth left? What happens if you use Chrome directly on the same host?
For me in general it takes between 2 to 15 seconds to load via vMix browser input depending on the nature and weight of the webpages. It's just a little bit slower but not much...
Guillaume
userr777
#3 Posted : Thursday, May 10, 2018 11:32:46 AM(UTC)
userr777
When I use chrome directly it works just fine, it takes less than 15 seconds to load a webpage.
#4 Posted : Thursday, May 10, 2018 12:12:12 PM(UTC)
I have no technical explanation, maybe you should contact vMix support directly for this issue.
Meanwhile you can still use Desktop Capture as a workaround
Guillaume
userr777
#5 Posted : Thursday, May 10, 2018 1:47:52 PM(UTC)
userr777
Guillaume
I am using Desktop Capture now but Web browser is more useful to me because I dont have to bring audio to vmix via stereo mix as I do when use Desktop Capture.
Thanks anyway
