Hello friends, I can do at the same time vmix broadcast on facebook and on youtube? what settings i do in configure streaming settings? Thank you Apostolos
Check the vMix Knowledge Base. Enter YouTube stream manually (or Facebook manually). https://www.vmix.com/knowledgeba...-facebook-live-with-vmixQuote:Why can't I stream to other providers when streaming to Facebook? Due to Facebook policy, it is not possible to stream to other providers at the same time when streaming to Facebook. When attempting to stream to other providers you will receive the following message: Streaming to other providers is not permitted when using the Facebook destination. This is a requirement of Facebook that all streaming programs such as vMix need to follow. As an alternative you are permitted to use the Manual Instructions process mentioned in the second half of the guide below: https://www.vmix.com/kno...-facebook-live-with-vmix
