Hello, I have big problem with external output. Im running on Intensity Pro 4K and Im getting many drops, totally random. Im running at 1080p59,94 (NTSC) and not every day, but often I get many dropped frames. I attached screens. https://gyazo.com/c7b3f5924cb0c01f5049cc6d7b248092 https://gyazo.com/1f6c61338204b0f1a43ffa3e49855e32I have to do a lot of restart to fix it, but its not real solution. Its not importand what is on output There is final stream: HW info: I7 - 7700K, 4,2Ghz 16GB RAM GEForce 1060 Intensity PRO 4K Same drops is also if I try fullscreen from GFX card.
Ok, maybe I know solution.
Its look like problem with 4K monitors.
OK, problem solved. It was corrupted nvidia drivers :(
