kgoodyer
#1 Posted : Saturday, April 28, 2018 12:00:44 AM(UTC)
kgoodyer
Was thanked: 53 time(s) in 27 post(s)
Looking at the following new features in 21 Beta
* New independent streaming support
All three streams can now be controlled independently. If one stops the others will continue.
This also allows a different audio bus to be sent to each stream to support multi lingual streaming setups.
* New Square (1:1) and Vertical (9:16) streaming options will automatically crop the sides of the video to fit.
New Square, Vertical Safe Area lines added to assist with adjusting the viewable area.
It would be nice if each stream could select any of the additional outputs, with separate overlay enables per stream, just like the NDI outputs.
This way I can have a set of 16:9 overlays for my youtube and broadcast (decklink)feeds, and a set of 1:1 overlays for my facebook feeds.
All The Best
Keith
