marcyaghi1
#1 Posted : Friday, April 27, 2018 3:54:22 AM(UTC)
marcyaghi1
Afganistan
Here is my first work on blend
Free Twitter animated title
download , install fonts and enjoy
File Attachment(s):
Twitter Animated.zip (210kb) downloaded 94 time(s).
marcyaghi1 attached the following image(s):
#2 Posted : Friday, April 27, 2018 6:16:48 PM(UTC)
@ marcyaghi1
Very cool, thanks for sharing.
Are you able to describe if the process was easy or perhaps what challenges you faced?
marcyaghi1
#3 Posted : Saturday, April 28, 2018 5:21:19 AM(UTC)
marcyaghi1
Afganistan
Well At The beginning it wasn't easy , just to know how to use blend first ,then if you designed before anything using flash or aftereffect , so you will know how it is working , just to know the simple tools , the great things is BLEND can impost PSD files , so you do the design on Photoshop then import it to blend , then start animations with some tweaks , 1st project took me 2 hours to make , but then this twitter took me 10 min to make. so , when you know some keys how to build , you will make anything you want , the way you want .
so after all , its very easy once you do the first project
