Feature Requests
Adjustment of focus of greenscreen (chromakeyed) backgrounds
Joined: 7/24/2014(UTC) Posts: 30 Location: Milton Keynes, UK
I'm not sure if this is a valid feature request, or that there might be other ways to achieve this?
But many times with a sharp greenscreen background image it looks sharper than the foreground camera image - and looks totally wrong.
Is there a way? Or could this be added to the Colour Key section of vMix perhaps? Such that the focus of the image could be adjusted?
Any thoughts or suggestions much appreciated!
Joined: 4/14/2013(UTC) Posts: 264 ![Man Man](/Themes/yafpro/male.gif) Location: Australia Thanks: 35 times Was thanked: 38 time(s) in 36 post(s)
Defocus has been requested several times but it's unlikely due to the processing demands but it could be restricted to high end gpus. Resolve will defocus in live mode. I don't know of other software that will defocus realtime ?
If your backgrounds aren't live you could pre produce softer versions. You could shoot a monitor with a camera.
Joined: 5/13/2014(UTC) Posts: 518 ![Man Man](/Themes/yafpro/male.gif) ![United Kingdom United Kingdom](/Content/images/flags/GB.png) Location: Manchester, UK Thanks: 2 times Was thanked: 183 time(s) in 130 post(s)
Adobe Premiere has had a Gaussian Blur real-time effect (using Nvidia Cuda GPUs) since CS5 (~2010), so I would think it's technically possible within vMix on a modern GTX card. Otherwise, for now, unless your chromakey background is live video, just pre-blur your background image/video via suitable editing software.
Joined: 7/1/2015(UTC) Posts: 1,151 ![Man Man](/Themes/yafpro/male.gif) ![United States United States](/Content/images/flags/US.png) Location: Houston TX Thanks: 319 times Was thanked: 263 time(s) in 233 post(s)
I would think that a simple convolution filter would be pretty lightweight. Might not offer as much control as you would like.
mjgraves wrote:I would think that a simple convolution filter would be pretty lightweight. Might not offer as much control as you would like. That sounds hopefull. There doesn't seem to be much interest in this but I use it a lot when using the Sony 7000 at work, sometimes it's upstream feeding vMix. Graphics or boxes on a defocussed live background looks so much more dimemsional or a curtain warmer wide shot prior to a live stream. I can then pull focus back to the camera clean with a mix. The Sony can defocus up to 18 live sources.
Peter B wrote:That sounds hopefull. There doesn't seem to be much interest in this but I use it a lot when using the Sony 7000 at work, sometimes it's upstream feeding vMix. Graphics or boxes on a defocussed live background looks so much more dimemsional or a curtain warmer wide shot prior to a live stream. I can then pull focus back to the camera clean with a mix. The Sony can defocus up to 18 live sources. Sure, you can use soft focus to mimic depth-of-field. I used to use this a lot when working post projects using Ultimatte.
Joined: 4/22/2016(UTC) Posts: 83 ![Man Man](/Themes/yafpro/male.gif) ![United Kingdom United Kingdom](/Content/images/flags/GB.png) Location: UK Thanks: 17 times Was thanked: 17 time(s) in 14 post(s)
If this could be done with a low performance hit, it would certainly be very convenient. +1
Feature Requests
