Hardware Compatibility
AsRock Z370 - Mini ITX Compatibility
Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
I just want to know if the AsRock Z370 Mini ITX Motherboard will work with an eGPU via Thunderbolt 3 as I'm planning to have a Yuan Quad/Magewell capture card installed there.
Thanks,
Sean
Joined: 8/29/2015(UTC) Posts: 136 Location: Seattle Wa
Thanks: 16 times Was thanked: 14 time(s) in 13 post(s)
 1 user thanked hellokitty for this useful post.
I dont have a egpu, but it does say it is supported with the intel thunderbolt software, i plugged a sonnet echo express 3d with 3 capture cards from aja, that worked. goodluck
