How can i make shortcut for next video in "video list" input
I try to find some solution how to next or previous video clip in "video list" input but i cant to find it. I have about 500-600 video clips and some of them long and some short and switch between them is realy important. Can you help me?
Rank: Staff
Groups: Registered, Administrators Joined: 12/13/2012(UTC) Posts: 244 Location: Gold Coast, Australia
Thanks: 7 times Was thanked: 160 time(s) in 73 post(s)
It sounds like you may prefer to use the "Playlist" feature instead (in the bottom right hand corner). This provides you with next and previous buttons in the settings.
Alternatively, you can right click the List input and select the next item you wish to play from the drop down that appears.
Playlist feature works different than List input, so it may not be an option for this particular use. To my knowledge there is no shortcut / api-call to advance a List input to the next entry (otherwise i'd use it in my scheduler application).
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
I'll add support for the NextPicture/PreviousPicture options to also control the List input in the final release of vMix 10. They should probably be renamed NextItem, PreviousItem as well if that doesn't break any existing 3rd party application functionality.
Martin vMix
PS: If you know the exact video in the list you wish to play you can use the SelectedIndex option and create a shortcut, selecting the video from the dropdown menu.
admin wrote:PS: If you know the exact video in the list you wish to play you can use the SelectedIndex function to (1 for first video, 2 for second etc)
So cool! I'll have to add the "list" functionality to my scheduler then... :-)
I think I spoke to soon, it only works when selecting a transition at the moment: Code:?Function=Fade&Input=1&SelectedIndex=3
admin wrote:I'll add support for the NextPicture/PreviousPicture options to also control the List input in the final release of vMix 10. They should probably be renamed NextItem, PreviousItem as well if that doesn't break any existing 3rd party application functionality.
it would be Great.
