dolfi
#1 Posted : Saturday, April 21, 2018 10:42:35 AM(UTC)
dolfi
Hi.
Hi.
I downloaded the UTC (Universal Title Controller) program for
control the xixl titles of VMix.
I want to ask the following:
a) If you have a conflict, use the UTC program with VMix, as regards UTC use
of IP 127.0.0.1 and port 8088 with WEB CONTROLLER option (192.168.1.21:8088) of Vmix,
considering that both programs run on the same PC?
b) When I ran the UTC program for the first time, I received a message
saying "NDI filter not recognized in your system"
Which option should I take register or cancel?
c) What is the RegisterFilters.cmd file used for and how is it installed correctly?
d) Why, when I choose any of the CREATE options (eg: Button, list, etc.) when the UTC program is running, does it delay in appearing the selected option or does it not appear directly?
#2 Posted : Saturday, April 21, 2018 11:37:45 AM(UTC)
Wow! Is it a new feature?
More seriously, please mind what you write, read yourself before posting
This is non-sense! Did you just try?
There is absolutely no conflict here. Both WebController and UTC will simply talk to vMix API at the given IP:PORT
Never seen this error message before.
Are you sure NDI is installed on your host (independently of vMix)?
Did you use the provided DLL for NDI provided by UTC
However using UTC with NDI on the same host as vMix does not make much sense. NDI is designed to be used over the network.
Did you try to find the answer in the vMixUTC post?
Certainly because your install seems to be very unappropriate, you don't seem to understand what you're doing and trying to use UTC in a way that's not recommended.
Again, best option is to use UTC on a remote host via the network. Otherwise just use vMix directly.
Guillaume
elgarf
#3 Posted : Friday, April 27, 2018 10:40:37 AM(UTC)
elgarf
Russian Federation
Was thanked: 231 time(s) in 130 post(s)
"Resister NDI filters" is for NDI Data provider, if filters not registered, NDI in UTC will not work.
