petervk
#1 Posted : Thursday, April 19, 2018 2:32:31 PM(UTC)
petervk
Hi there,
I use an Yamaha MG12XU audio mixer with USB interface wich works fine but does not seem to work with vMix. It is definately a Vmix issue as audio input/output to de PC as such works fine. But As soon as I start vMix only crap comes out of vMix.
Sometimes when I reset the audio input it looks like to work fine and then after a minute or so the drama starts all over again.
The input via USB then still works fine (when I enable the 'listen to' option in the recording device options) and the audio other than that from vMix also comes out perfectly.
It looks like vMix is having a problem with the sample frequency as (apart from the pumping distortion) the audio seems to be pitched up. May be from 44.1kHz to 48kHz(?)
Somebody any ideas?
Thanks,
Peter.
ovinas
#2 Posted : Thursday, April 19, 2018 5:09:59 PM(UTC)
ovinas
Yamaha Steinberg USB Driver installed?
petervk
#3 Posted : Friday, April 20, 2018 2:07:54 AM(UTC)
petervk
Yes I did.
stevespaw
#4 Posted : Friday, April 20, 2018 9:44:22 AM(UTC)
stevespaw
Was thanked: 75 time(s) in 57 post(s)
Are you using this as an ASIO device?
Steve
petervk
#5 Posted : Friday, April 20, 2018 12:58:09 PM(UTC)
petervk
Steve
Yes I do.
petervk attached the following image(s):
#6 Posted : Friday, April 20, 2018 1:41:50 PM(UTC)
Was thanked: 794 time(s) in 589 post(s)
You might want to try with generic Asio drivers : Asio4All
I'm not sure it makes a difference but it solved problems others were having.
Most asio drivers are really optimized for absolute realtime in general for music production vith a DAW. Did you try "smoothing" things a bit ? Loosing a few ms is not a big deal, vMix will not suffer from having + 10 ms in latency.
My 2 cts
Guillaume
petervk
#7 Posted : Friday, April 20, 2018 1:53:51 PM(UTC)
petervk
My 2 cts
Guillaume
Thanks Guillaume,
I downloaded the driver (V1.9.10-2) from:
http://www.yamahaproaudi...firmware_software/mg_xu/
But now it turns out that there is a newer version (V1.10.0) on:
https://www.steinberg.ne...teinberg_usb_driver.html
How weird that the Yamaha site (the mixer brand) is not up-to-date while the driver is dated December 28, 2017! Anyway, the first tests look fine. So far no problems with the newest driver. I'm happy. :-)
Cheers,
Peter.
#8 Posted : Friday, April 20, 2018 5:36:30 PM(UTC)
There might be an "official" manufacturer driver and another one developped by Steinberg.
I can understand if Yamaha would not show the competition solution in this case.
Anyway, if you're happy finally, that's the main thing to take into account!
Have fun!
ovinas
#9 Posted : Saturday, April 21, 2018 1:19:28 AM(UTC)
ovinas
Steinberg is part of the Yamaha company, so no competition...
Guest (4)
