spencerm24
#1 Posted: : Wednesday, April 18, 2018 11:21:44 AM(UTC)
spencerm24
It would be nice if when using a camera with 2 channels of embedded audio, we can have independent control of each signal when it is set to "separate mono". So I can send Ch1 to master, and Ch2 to Bus A. Also would be nice to independently on/off each channel of those two, right now when you turn audio on/off, it affects both channels.
This shouldn't be that hard to implement, as separate mono already gives us two faders, just add a second M/A/B and on/off icon to the second channel.
dark_ata
#2 Posted : Wednesday, April 18, 2018 11:45:25 AM(UTC)
dark_ata
Was thanked: 18 time(s) in 13 post(s)
you can do it with ndi only audio, we usually record the mix(1-2), the master audio camera(2-3), and another camera or ambient (4-5)
zenvideo
#3 Posted : Wednesday, April 18, 2018 12:50:33 PM(UTC)
zenvideo
You can use the Channel Matrix for this purpose, to send Ch1 to Master (L & R), and then Ch2 to Bus A (L & R). As per the attached pic.
zenvideo attached the following image(s):
spencerm24
#4 Posted : Wednesday, April 18, 2018 12:56:44 PM(UTC)
spencerm24
That would work, but a way to hot switch the routing, right now we have A/B/M buttons on all audio sources, for easy quick toggling, but the separate mono only has an A/B/M button for both of them combined.
