marcyaghi1
#1 Posted : Friday, April 13, 2018 4:56:49 AM(UTC)
marcyaghi1
Afganistan
Please consider this , we needed so badly
Vmix DATA SOURCE can take data from sql database
regards
#2 Posted : Friday, April 13, 2018 5:41:13 AM(UTC)
we have beeing doing just that lately with great succes for sports data and results
have a appropriate php file including the wanted queries echo the results to a xml or json format on a server or even a local server (XAMMP) and let datasources link to that php file
#3 Posted : Friday, April 13, 2018 6:23:07 AM(UTC)
Just like Doggy, I wrote my own PHP script (could be done with ASP too) that converts MySQL data (could be any database format) into XML so that vMix can use it.
Guillaume
marcyaghi1
#4 Posted : Friday, April 13, 2018 1:56:38 PM(UTC)
marcyaghi1
Afganistan
thanks doggy and DWAN, well good you did that
so help me out please guys , any links , any one have example ,what about wordpress cms??
help please even here or in pm
thanks a lot
Regards
#5 Posted : Friday, April 13, 2018 2:11:11 PM(UTC)
marcyaghi1
#6 Posted : Friday, April 13, 2018 3:04:44 PM(UTC)
marcyaghi1
Afganistan
thanks DWAN
but i`m not a developer my self , thanks for the link , but how to make this happen live ,
just to ask you if you have a demo script that i can use and try to get it developed
thanks a lot
#7 Posted : Friday, April 13, 2018 3:12:00 PM(UTC)
If you are not a developer, there is no way you can do it by yourself
Find a developer that can help
Oh, it's DWAM btw
#8 Posted : Friday, April 13, 2018 8:40:15 PM(UTC)
use at own risk ( tricky item to ask database acces of third party )
xxxx to be replaced by appropriate data
Created after using lots of DWAM his link ;-)
Code:
<?php
// Initialize variable for database credentials
$dbhost = 'xxxx';
$dbuser = 'xxxx';
$dbpass = 'xxxx';
$dbname = 'xxxx';
$table = 'xxxx';
//Create database connection
  $dblink = new mysqli($dbhost, $dbuser, $dbpass, $dbname);
//Check connection was successful
  if ($dblink->connect_errno) {
     printf("Failed to connect to database");
     exit();
//Fetch rows from table
  $result = $dblink->query("SELECT xxxx FROM $table ");
//Initialize array variable
  $dbdata = array();
//Fetch into associative array
  while ( $row = $result->fetch_assoc())  {
       # Converting each column to UTF8
        $row = array_map('utf8_encode', $row);
        array_push($dbdata,$row);
//var_dump($dbdata);
//Print array in JSON format (for direct access from vMix datasource link to this php file)
echo json_encode($dbdata);
vijay6672 on 4/14/2018(UTC)
marcyaghi1
#9 Posted : Saturday, April 14, 2018 9:27:51 AM(UTC)
marcyaghi1
Afganistan
Hello doggy
thanks for you help
I have used you script as you mentioned
here is the result
[{"post_title":"\u00d8\u00a3\u00d9\u0087\u00d9\u0084\u00d8\u00a7\u00d9\u008b \u00d8\u00a8\u00d8\u00a7\u00d9\u0084\u00d8\u00b9\u00d8\u00a7\u00d9\u0084\u00d9\u0085 !"},{"post_title":"\u00d9\u0085\u00d8\u00ab\u00d8\u00a7\u00d9\u0084 \u00d8\u00b9\u00d9\u0084\u00d9\u0089 \u00d8\u00b5\u00d9\u0081\u00d8\u00ad\u00d8\u00a9"},{"post_title":"\u00d9\u0085\u00d8\u00b3\u00d9\u0088\u00d8\u00af\u00d8\u00a9 \u00d8\u00aa\u00d9\u0084\u00d9\u0082\u00d8\u00a7\u00d8\u00a6\u00d9\u008a\u00d8\u00a9"},{"post_title":"intt-w"},{"post_title":"Vnewsroom"},{"post_title":"Auto Draft"},{"post_title":"Auto Draft"},{"post_title":"Auto Draft"},{"post_title":"\u00d9\u0085\u00d8\u00b3\u00d9\u0088\u00d8\u00af\u00d8\u00a9 \u00d8\u00aa\u00d9\u0084\u00d9\u0082\u00d8\u00a7\u00d8\u00a6\u00d9\u008a\u00d8\u00a9"},{"post_title":"news"},{"post_title":"Auto Draft"},{"post_title":"Auto Draft"},{"post_title":"Auto Draft"},{"post_title":"Auto Draft"},{"post_title":"\u00d9\u0085\u00d8\u00b3\u00d9\u0088\u00d8\u00af\u00d8\u00a9 \u00d8\u00aa\u00d9\u0084\u00d9\u0082\u00d8\u00a7\u00d8\u00a6\u00d9\u008a\u00d8\u00a9"},{"post_title":"\u00d9\u0085\u00d8\u00b3\u00d9\u0088\u00d8\u00af\u00d8\u00a9 \u00d8\u00aa\u00d9\u0084\u00d9\u0082\u00d8\u00a7\u00d8\u00a6\u00d9\u008a\u00d8\u00a9"},{"post_title":"\u00d9\u0085\u00d8\u00b3\u00d9\u0088\u00d8\u00af\u00d8\u00a9 \u00d8\u00aa\u00d9\u0084\u00d9\u0082\u00d8\u00a7\u00d8\u00a6\u00d9\u008a\u00d8\u00a9"},{"post_title":"\u00d9\u0085\u00d8\u00b3\u00d9\u0088\u00d8\u00af\u00d8\u00a9 \u00d8\u00aa\u00d9\u0084\u00d9\u0082\u00d8\u00a7\u00d8\u00a6\u00d9\u008a\u00d8\u00a9"},{"post_title":"\u00d9\u0085\u00d8\u00b3\u00d9\u0088\u00d8\u00af\u00d8\u00a9 \u00d8\u00aa\u00d9\u0084\u00d9\u0082\u00d8\u00a7\u00d8\u00a6\u00d9\u008a\u00d8\u00a9"},{"post_title":"\u00d9\u0085\u00d8\u00b3\u00d9\u0088\u00d8\u00af\u00d8\u00a9 \u00d8\u00aa\u00d9\u0084\u00d9\u0082\u00d8\u00a7\u00d8\u00a6\u00d9\u008a\u00d8\u00a9"},{"post_title":"\u00d9\u0085\u00d8\u00b3\u00d9\u0088\u00d8\u00af\u00d8\u00a9 \u00d8\u00aa\u00d9\u0084\u00d9\u0082\u00d8\u00a7\u00d8\u00a6\u00d9\u008a\u00d8\u00a9"},{"post_title":"\u00d9\u0085\u00d8\u00b3\u00d9\u0088\u00d8\u00af\u00d8\u00a9 \u00d8\u00aa\u00d9\u0084\u00d9\u0082\u00d8\u00a7\u00d8\u00a6\u00d9\u008a\u00d8\u00a9"},{"post_title":"\u00d9\u0085\u00d8\u00b3\u00d9\u0088\u00d8\u00af\u00d8\u00a9 \u00d8\u00aa\u00d9\u0084\u00d9\u0082\u00d8\u00a7\u00d8\u00a6\u00d9\u008a\u00d8\u00a9"},{"post_title":"front"},{"post_title":"\u00d9\u0085\u00d8\u00b3\u00d9\u0088\u00d8\u00af\u00d8\u00a9 \u00d8\u00aa\u00d9\u0084\u00d9\u0082\u00d8\u00a7\u00d8\u00a6\u00d9\u008a\u00d8\u00a9"},{"post_title":"News Woman on Green Screen"},{"post_title":"erqwerwer"},{"post_title":"\u00d8\u00a3\u00d9\u0087\u00d9\u0084\u00d8\u00a7\u00d9\u008b \u00d8\u00a8\u00d8\u00a7\u00d9\u0084\u00d8\u00b9\u00d8\u00a7\u00d9\u0084\u00d9\u0085 !"},{"post_title":"\u00d8\u00a3\u00d9\u0087\u00d9\u0084\u00d8\u00a7\u00d9\u008b \u00d8\u00a8\u00d8\u00a7\u00d9\u0084\u00d8\u00b9\u00d8\u00a7\u00d9\u0084\u00d9\u0085 !"},{"post_title":"GTITLE"},{"post_title":"\u00d9\u0085\u00d8\u00b1\u00d8\u00ad\u00d8\u00a8\u00d8\u00a7 \u00d8\u00a8\u00d9\u0083\u00d9\u0085"},{"post_title":""},{"post_title":"\u00d9\u0085\u00d8\u00b3\u00d9\u0088\u00d8\u00af\u00d8\u00a9 \u00d8\u00aa\u00d9\u0084\u00d9\u0082\u00d8\u00a7\u00d8\u00a6\u00d9\u008a\u00d8\u00a9"},{"post_title":"\u00d9\u0085\u00d8\u00b3\u00d9\u0088\u00d8\u00af\u00d8\u00a9 \u00d8\u00aa\u00d9\u0084\u00d9\u0082\u00d8\u00a7\u00d8\u00a6\u00d9\u008a\u00d8\u00a9"},{"post_title":"1"},{"post_title":"\u00d9\u0085\u00d8\u00b1\u00d8\u00ad\u00d8\u00a8\u00d8\u00a7 \u00d8\u00a8\u00d9\u0083\u00d9\u0085"}]Back to to
it it seams i cant read anything in it
and here is vmix recall
marcyaghi1 attached the following image(s):
marcyaghi1
#10 Posted : Saturday, April 14, 2018 9:29:04 AM(UTC)
marcyaghi1
Afganistan
Oh, it's DWAM btw
sorry for that mistake DWAM
and thanks for the help
#11 Posted : Saturday, April 14, 2018 11:06:07 AM(UTC)
here is the result
Doesn't say much does it?
what type of database you want to pull your data from (sql, mysql, other), whats it structure, what does it contain , is its structure even correct ( i had to pull data from a mysql which collumns headers where totally wrong even and had to write a corrector for it", where is it, what are your queries (filtered, sorted , selections etc) and soooooo much more.
Like DWAM already said "If you are not a developer, ....." and you want one to do it for you , you will need to give a lot more information than just "I like database data into datasources in vMix"
I did it the way DWAM sugested , lots of times as i am not a developer but suggestions in the forum tend to push one in the right direction
There is also a reason i had lots of XXXX in the code, having acces to such a database with the needed credentials is more thn just readable !
#12 Posted : Saturday, April 14, 2018 11:56:20 AM(UTC)
Again, find a dev in your country who speaks your native language.
Even a student can do this for you, especially if you find a little money for his work. This cannot be done for free if you want something that works quickly and reliably. Or just learn how to do it if you have months ahead.
This is pro stuff, there is no magic keyword for this type of things: it's a lot of very valuable work!
Good luck!
Guillaume
#13 Posted : Saturday, April 14, 2018 12:10:52 PM(UTC)
@Doggy
Your script works perfectly btw... Guess you know it already ;o)
@Marc
Your database must be formatted for Lebanon I guess
Guillaume
#14 Posted : Saturday, April 14, 2018 12:53:29 PM(UTC)
DWAM wrote:
@Doggy
Merci, it did perform well used intensivly over a 4 day show pulling 4 rows constantly that changed data (ahtletes name) each seperate around once per 45 seconds. Did the filtering in the query itself but guess you know why :-) . data pulled to 4 different streaming unit (arenas) for each specific athletes data in title. Further scripts did use same data for other processing (naming each individual recording etc )
Did omit in the posted code the function to clean the collumn headers illigal characters and such ( yeah technically bad practise form the data provider) but glad we had accesS in the first place (a very important trust issue !).
Had an to xml version also and or ability to save pulled data as xml or json file on the server.
advantage of xml version is the possibility to further filter data in the datasource table through the xpath details though if needed.
we did have in the beginnig an issues, basically i did put the files on my own shared server which colled the remote data server and because we had left all the variations in the datasource setup (it basically crashed the server ( processor and memory overload).
Lesson learned , check the update frequencies in vMix and delete the ones you are not using ;-). i later moved the scripts to a local server on the laptop (to keep my webhost happy also).
having not to manually pick data for the titlefrom a list, combined with pulling each stopwatch display data (serial) for the title that also triggered the individual recordings made it easyer to focus on the footage (times 4)
#15 Posted : Saturday, April 14, 2018 1:22:57 PM(UTC)
Good job!
yes using a local server is always better. I have a RPI with LAMP in my toolbox, ready to go for small projects.
My script for XML does extensive use of query strings and parsing in order to use dynamic SQL queries so that a single script can be used for several tables and use cases but I got stuck (my fault I think) at using some of the SQL syntax possibilities for queries (things like CONCAT(), or TRUNCATE()) I wanted to use on the server side to make sure my formatting would be better and easier when creating the XAML part... Works against the database directly, but not in my script ??? Argh! Need to work more I guess ! ;o)
#16 Posted : Saturday, April 14, 2018 1:38:43 PM(UTC)
@ DWAM
FYI, the reason i had to add a correction function was due to how vMix handles "illigal characters" in the data specificaly while it otherwise in use ( creating xml files for example) had no problems !
#17 Posted : Saturday, April 14, 2018 1:42:52 PM(UTC)
This is not the problem I'm facing. The error occurs in the script and there are no illegal characters in my tables!
marcyaghi1
#18 Posted : Saturday, April 14, 2018 2:57:17 PM(UTC)
marcyaghi1
Afganistan
Error in the script
I figure it out
here the fix
$row = array_map('utf8_decode', $row);
you should put utf8_decode instead of utf8_encode
then it will work in vmix you will see results
i still see some ??????? symbols due to Arabic characters , need to find out an add for the script for Unicode characters
Regards
#19 Posted : Saturday, April 14, 2018 3:25:33 PM(UTC)
glad you solved part of it
but.... for me it's not an error in the script as is !
More likely the database you are accessing has a different DEFAULT CHARACTER SET (which would make sence as you mention 'i still see some ??????? symbols due to Arabic characters' )
Michał
#20 Posted : Saturday, April 4, 2020 5:12:12 AM(UTC)
Michał
Poland
I have a solution for json. All language
Your database must have (DEFAULT CHARACTER SET utf8 COLLATE utf8_xxxx_ci) and all tables
  • you can make these changes in the mysql workbench or phpmyadmin
*utf8_xxxx_ci - xxxx your language
Code:
<?php
$dbhost = 'xxxx';
$dbuser = 'xxxx';
$dbpass = 'xxxx';
$dbname = 'xxxx';
$table = 'xxxx';
  $dblink->set_charset("utf8");
     exit();
  $dbdata = array();
header('Content-Type: application/json');
print(json_encode($dbdata, JSON_UNESCAPED_UNICODE | JSON_UNESCAPED_SLASHES | JSON_PRETTY_PRINT));
i will add:
Code:
remove:
Code:
and add:
Code:
Similar Topics
VMIX data sources not updating (XML/JSON) (General Discussion)
by themoog 8/20/2023 6:33:30 PM(UTC)
Session or Cookie based JSON for vMix Data Source (General Discussion)
Belarus NSCPro 9/1/2022 11:49:18 PM(UTC)
vmix data source triggering layers on xaml/gt (General Discussion)
by discodanz 6/18/2021 9:58:57 AM(UTC)
