66 Pages«<2526272829>»
JAIRODJ
#521 Posted : Tuesday, April 10, 2018 3:41:50 PM(UTC)
JAIRODJ
Was thanked: 16 time(s) in 12 post(s)
Greetings, I have tried to use NDI, but it does not show the window with the video, only the option to choose the source appears but it does not load the window or show anything.
I followed all the recommendations, installed NDI Tools and others, but none of them worked.
I have tested if the signal is present in the network and if it is, the tests were made with:
- Zen NDIdual monitor
- Studio monitor newtek
- vMix
All if they recognize and show video, only UTC does not.
I am using (NDI Monitor Data Provider for UTC (updated 12.02.2018)).
Perform a test with the previous version of (NDI Monitor Data Provider for UTC 04-09-2017) and if it worked perfect. Then I deduced that the fault comes from the new dll (NDI-12-02-2018)
Joeboe
#522 Posted : Tuesday, April 10, 2018 6:55:08 PM(UTC)
Joeboe
I never got any version to work...on none of my 3 PCs
Siroki
#523 Posted : Friday, April 13, 2018 5:37:49 AM(UTC)
Siroki
Bosnia and Herzegovina
Was thanked: 27 time(s) in 24 post(s)
I need little help!
FIBA has a new match organizer, live stats, rosters and stuff for lvie match and after match statistics.
Is it able over UTC to pull this stuff?
For example there is a option for exporting roster to .xls file:
http://basket.ba/tim?tea...sonId=100601#mbt:281-200$t&0=2
How can I import that .xls or part of .xls (active players for match) to title in vMix? Is there option for that at all?
I don't need stats for each player during match, only roster and maybe match stats for team at half time and at the end of the match
Thanks for every help
Best regards
#524 Posted : Friday, April 13, 2018 5:58:15 AM(UTC)
opening the downloaded .xls with datasources and link them to a title ?
#525 Posted : Friday, April 13, 2018 6:20:03 AM(UTC)
Hi Siroki
So far UTC only supports XML datasources natively.
However vMix does support XLS and UTC can control almost any aspect of your vMix production remotely via the API.
For example, watch this video I did long ago where I have an XML datasource into vMix and UTC is used to control all the titles. There is a roster title where each team player is presented individually (but a global line-up could be done too)
Hope this helps
Guillaume
Siroki
#526 Posted : Friday, April 13, 2018 8:43:55 AM(UTC)
Siroki
DWAM wrote:
Hi Siroki
Hope this helps
Guillaume
I am so bad at this XML, XLS and datasources :(
I will give it a try
thank you guys
corporatejames
#527 Posted : Sunday, May 6, 2018 11:07:25 PM(UTC)
corporatejames
Having a couple bugs with the overlayin and overlayout where it does the overlayout or starts xaml incorrectly randomly.
if do the overlayin in vmix by pressing the number 1 button as example the xaml works fine. Previous version of UTC was ok from memory.
kevev
#528 Posted : Friday, May 18, 2018 9:00:47 PM(UTC)
kevev
Was thanked: 9 time(s) in 5 post(s)
DWAM wrote:
I have had issues on long period of times yes.
Check the log file, sometimes it gets so huge that the system gets unresponsive.
Same issue here. It would be nice if the developer could figure out why disabling logging does nothing as the app still logs activity constantly. Or maybe the developer could enable automatic log rotation after a certain size. Also delete old logs Great app though! :)
desmar
#529 Posted : Thursday, June 7, 2018 11:30:48 AM(UTC)
desmar
Canada
@elgarf
Feature Request
1) Support for sliders and rotating nobs..
2) VST3 Pluggins
elgarf
#530 Posted : Thursday, June 7, 2018 11:34:38 AM(UTC)
elgarf
Groups:: Registered
Russian Federation
Was thanked: 231 time(s) in 130 post(s)
What VST3 plugins can do?)
desmar
#531 Posted : Thursday, June 7, 2018 7:38:02 PM(UTC)
desmar
Canada
Ability to control VST 3 Plugins.. From within UTC..
VSTXML for remote controllers
Remote controllers for audio and MIDI software applications have become increasingly popular. With VSTXML, VST3 offers far more flexible control of VST plug-ins by remote controllers. Using the knobs and faders on the control surface, parameters can be recorded, renamed and edited in many ways. Parameters that cannot be edited can be routed for display purposes to the control surface, for example to show Gain Reduction on compressor.
kevev
#532 Posted : Saturday, June 16, 2018 1:44:22 PM(UTC)
kevev
Good news! Logging disable is fixed. I haven't updated in a while so I download the latest version. It seems to not log anymore when logging is disabled. Hoping this fixes the slow down.
spencerm24
#533 Posted : Monday, June 25, 2018 1:29:20 AM(UTC)
spencerm24
This could be perfect to control my second stream and record PC from the main one. two questions:
-Can we get an update to support independant stream control? Right now start/stop stream does all 3. I'd like to be able to do them independently, since vMix now supports this in shortcuts.
-Is there a way to make a "record toggle" light up red when it is recording?
elgarf
#534 Posted : Monday, June 25, 2018 2:26:14 AM(UTC)
elgarf
Groups:: Registered
Russian Federation
@spencerm24, try this Functions.xml.
Try make "Record" button in UTC "State Dependent".
25.06.2018, updated with new archive. There was error into Functions.xml =(
File Attachment(s):
Functions.zip (3kb) downloaded 32 time(s).
TYPLive
#535 Posted : Tuesday, June 26, 2018 8:22:05 PM(UTC)
TYPLive
*Query Solved nevermind. 2am issues ;) )
I am wondering if its possible to use UTC on a different pc thats on the network. Im wanting to use my win10 tablet to use UTC while i use my main pc for vmix only.
kevev
#536 Posted : Thursday, June 28, 2018 2:05:50 PM(UTC)
kevev
That is exactly what we do. It works great.
corporatejames
#537 Posted : Tuesday, July 10, 2018 2:49:17 AM(UTC)
corporatejames
Hi @elgarf
Are you able to create a new widget called Image Field?
This will be the same as the text field but will include a small image icon on the right side of the text field
that opens up Windows Explorer and lets the user choose the file. Then once selected copies the
image path to text field. (handy for first time users and speeds up changing images for titles.
The path would use the full directory path C:\folder\img.jpg ... but the user can also just paste a URL if needed.
If this could be created soon that would be awesome.
James
#538 Posted : Tuesday, July 10, 2018 5:16:26 AM(UTC)
James
I believe it's not that easy expecially when UTC's not used on the same host as vMix, where UNC paths would be irrelevant in the end.
Guillaume
corporatejames
#539 Posted : Wednesday, July 11, 2018 3:05:52 AM(UTC)
corporatejames
James
Guillaume
I agree but would be handy and speed up the process when used on the same pc. Some users take longer to explain entering the path to the image.
All my setups but Dropbox in the same location at C:\Dropbox\ASN so that the path will be same on both pcs. This allows me to sync all new images for events
to each pc and control from the CMS.
brownm
#540 Posted : Tuesday, July 17, 2018 2:20:52 PM(UTC)
brownm
I'm so happy I discovered UTC, this software is amazing!
I do have a feature request though (or this may be possible and I'm just missing how). The ability to queue changes would be incredible.
Here's my situation- we want to use UTC to control our graphics for American Football. When we're updating the Down & Distance "1st & 10, 2nd & 8, and so on" it would be nice to be able to select "1st" from the drop down, then type "12" in a text field and hit a button that would send those changes to vmix.
As it stands right now we would be on "1st & 10" and the play would happen. Now the operator drops down to "2nd" and has to quickly type over the "10" with the new value.
Guest (22)
