Joined: 3/10/2017(UTC) Posts: 63 Location: Philadelphia
Thanks: 51 times Was thanked: 1 time(s) in 1 post(s)
Will you guys add Live polling as a feature in Vmix? If not, is there any 3rd party add-on that you can recommend?
Joined: 3/15/2018(UTC) Posts: 82  Thanks: 5 times Was thanked: 10 time(s) in 8 post(s)
Joined: 2/16/2017(UTC) Posts: 125   Thanks: 25 times Was thanked: 25 time(s) in 18 post(s)
I know it's not the easiest way, but you can do it with Google Forms and data sources. PTZ Optics was using it and I have done a small test and it's working great. A build in solution however would be great or, what I prefer" an external plugin.
