dionv
#1 Posted : Friday, April 6, 2018 8:56:39 PM(UTC)
dionv
Thanks to this post: https://forums.vmix.com/....aspx?g=posts&t=5473 I have been able to hack a bit of a 3D rotation into the MultiViewHD XAML file.
But, somewhere along the way, I messed something up, and instead of a nice rotation around the X axis, it goes about 45 degrees, then "flips" to -45, rotates through 0 to 45 again, and "flips" back.
Just wondering if someone could have a look at what I'd done and offer some pointers?
Once the X rotation is figured out, I'm hoping to be able to put the photos off-kilter on the Y axis, and expand the area in include the names under the photos.
Once I get something decent finished, I'll share it out (seems only fair).
Thanks in advance for any pointers.
Dion
EDIT: Replaced the ZIP file 2018-04-06 hopefully with proper pointers to images.
File Attachment(s):
Multi-View-3D-Test.zip (487kb) downloaded 19 time(s).
#2 Posted : Friday, April 6, 2018 9:23:20 PM(UTC)
@ dionv
I think you may have to provide additional files with your XAML file as the relative path to the image source is not going to be on anyone's PC...
ERROR message
Could not find a part of the path 'C:\Users\dion\Documents\CompData\PlayerPhotos\MultiViewHD.xaml.png'
dionv
#3 Posted : Friday, April 6, 2018 10:07:53 PM(UTC)
dionv
IceStream wrote:
@ dionv
ERROR message
Whups! Forgot about that!
Attached is a ZIP file with the images. Extract and load from the same directory should work now.
File Attachment(s):
Multi-View-3D-Test.zip (487kb) downloaded 16 time(s).
#4 Posted : Saturday, April 7, 2018 5:07:11 AM(UTC)
still need to change to: ImageSource="MultiViewHD.xaml.png"/
dionv
#5 Posted : Saturday, April 7, 2018 7:33:32 AM(UTC)
dionv
Sorry. I renamed all the images and re-attached the zip file to my original post above.
Dion
