jtoney
#1 Posted : Thursday, April 5, 2018 11:01:23 PM(UTC)
jtoney
I need to get video out of my program via SDI. I have a Matrox MXO2 LE and a Decklink Duo. I'll be using all the inputs from these devices for my cameras. Is there any way to get video back out of any of these devices?
SportsNetUSA.net
#2 Posted : Friday, April 6, 2018 6:56:04 PM(UTC)
SportsNetUSA.net
From Matrox MX02LE Technical Specs
SDI output
2 indentical SD or HD outputs for simultaneous monitoring and recording
16 channels of embedded audio on Mac
8 channels of embedded audio on the PC
Compliant with SMPTE 259M, SMPTE 272M, SMPTE 292M, SMPTE 299M
BNC connector (75 Ω)
thanks 1 user thanked SportsNetUSA.net for this useful post.
rowby on 4/6/2018(UTC)
zenvideo
#3 Posted : Friday, April 6, 2018 10:12:26 PM(UTC)
zenvideo
SDI output
That's the spec of what the hardware is capable of. However, without software support you won't be able to use the outputs in the way that you probably want to. AFAIK, vMix supports output to AJA, Blackmagic and Bluefish444 cards, so that doesn't include the Matrox MXO2 range.
SportsNetUSA.net on 4/7/2018(UTC)
SportsNetUSA.net
#4 Posted : Saturday, April 7, 2018 11:05:48 PM(UTC)
SportsNetUSA.net
@jtoney
Are you referring to vMix or just using an output for some other device (monitor, recorder, etc.)?
jtoney
#5 Posted : Tuesday, May 1, 2018 5:06:06 AM(UTC)
jtoney
Vmix, yes. I also have a decklink hd dual link card (the pci-x version). However it seems that vmix locks the black magic cards and I can only do inputs with any of these. Nothing seems to actually send video out of the application. Ultimately what I need to do is have three cameras in, another source via ndi, and an output 2 Sdi for my projector.
#6 Posted : Tuesday, May 1, 2018 9:17:17 AM(UTC)
Just use a HDMI to SDI converter on one of your graphic card outputs (even with a splitter to keep PGM monitoring for yourself)
Guillaume
jtoney
#7 Posted : Wednesday, May 2, 2018 1:39:26 PM(UTC)
jtoney
I'm out of time and I don't have enough adapters to make that work.
Is there no ouput option on the MXO2 LE in VMIX?
Guest (4)
