I m streaming often time to facebook page with very nice result using stream fonction of vMix. When publishing from vMix, on the facebook page it says that the stream was "published by vMix".
Do you know if there is a way to modify this and how ?
Thank you for any help
Pierre
Joined: 2/18/2014(UTC) Posts: 1,846 Location: Stockholm
Hi pierk, AFAIK that is nothing you can change, but "Published by" is only visible to Admins/Editors of the page (not the public) if I remember it correctly.
 2 users thanked richardgatarski for this useful post.
Joined: 4/18/2016(UTC) Posts: 223 Location: United Kingdom
Thanks: 33 times Was thanked: 37 time(s) in 31 post(s)
richardgatarski wrote:Hi pierk, AFAIK that is nothing you can change, but "Published by" is only visible to Admins/Editors of the page (not the public) if I remember it correctly. This is correct, if you put the cursor over the "published by" it will tell you only page editors and administrator can see the message.
 1 user thanked NHT for this useful post.
Thank you for your responses. I have checked with a public account and there is no "published by" then.
Have a nice evening
Pierre
