Eriksson88
#1 Posted : Tuesday, March 27, 2018 6:14:59 PM(UTC)
Eriksson88
This is my first post so I'd like to say hello all Vmix users. I've got an issue with keyboard combination. There are some Polish letters which I need to use combination alt + letter. Almost all are working good (f.i. alt + s, alt + z etc.), but when I use alt + a, it causes erase area from input (see pictures below). Anybody has that kind of trouble and has found a solution? Thanks in advance for all replies.
NHT
#2 Posted : Tuesday, March 27, 2018 6:34:17 PM(UTC)
NHT
Can you write the text in Word or similar then cut and paste it in?
Eriksson88
#3 Posted : Wednesday, March 28, 2018 1:19:43 AM(UTC)
Eriksson88
I use Notepad every time I need this letter but for sure it's quite uncomfortable. Problem with combination alt + a exists only in vMix. I haven't got any shortcut with alt / a.
MrKrotos
#4 Posted : Wednesday, March 28, 2018 8:06:43 AM(UTC)
MrKrotos
But can you use the Alt +a in Notepad?
Eriksson88
#5 Posted : Wednesday, March 28, 2018 12:02:32 PM(UTC)
Eriksson88
Yes, I can use it in some text editors. The problem exists only in vMix.
Eriksson88
#6 Posted : Saturday, March 31, 2018 3:59:35 PM(UTC)
Eriksson88
Any ideas? I did my best but I didn't find solution. It doesn't depend from PC, because I've got problem on two computers, my friend has also on another one.
r@wisla
#7 Posted : Saturday, March 31, 2018 9:33:00 PM(UTC)
r@wisla
Was thanked: 40 time(s) in 37 post(s)
I can confirm this bug.
Looks like alt + a behaves in title window as ctrl + a. It marks all the text, while it shouldn’t. Then, when we hit next letter it replaces previously marked text.
When we need the „ą” letter we write text in notepad and paste it to vmix title tindow.
Eriksson88
#8 Posted : Sunday, April 1, 2018 11:42:45 AM(UTC)
Eriksson88
It doesn't also depend from keyboard's language used in Windows. I switched on ENG version and when I enter ALT + A the effect is the same. Maybe Admin can help us?
