2 Pages<12
desmar
#21 Posted : Tuesday, March 27, 2018 12:55:53 AM(UTC)
desmar
Canada
@Brutuss
You should contact Martin at vMix to use your graphic designs here to give vMix a new fresh look.
You should contact @Elgarf and work with him to work on the vMix UTC project.
Using his open source code with your graphic designs here and combine your work.
to make vMix UTC better.
Brutuss wrote:
I'm a graphic designer - my layout proposal:
v1
v2
v2a
WORK WORK WORK ! ! ! :D :)
Frank Broughton
#22 Posted : Tuesday, April 10, 2018 12:13:21 PM(UTC)
Frank Broughton
Love your design skills! That blue with black in my favorite color combination.
marcyaghi1
#23 Posted : Tuesday, April 10, 2018 12:19:45 PM(UTC)
marcyaghi1
Afganistan
wow dude , your design is perfect, i hope to see this working really soon especial the play icons in the button
please make this happen soon
azanisarri
#24 Posted : Wednesday, January 9, 2019 11:39:23 AM(UTC)
azanisarri
Malaysia
Originally Posted by: raugert Go to Quoted Post
***** Update.. this application was a first attempt at a programmable controller and has been abandoned. It has been replaced with the "vMix Custom Panel Builder" . You can find it in the 3rd party forum as well.. ****
Like many folks, I was looking for a controller that I could use with vMix to switch video, do replays and control audio with programmable buttons rather than click all over a multiview screen to cut a show. I liked the idea of a midi controller like X-Keys or Akai, but I also wanted to be able to easily label the buttons and have separate configurations for different shows. So I figured I would write one. This app basically sends commands to vMix using the Web API. So anything that is in the vMIx shortcuts can be used. You can configure any button and customize the layout to whatever you like.
Highlights:
- Buttons are configurable to any vMix shortcut in the Web API
- Buttons can be labelled (use a comma between words to place each word on a separate line)
- Separate configurations can be saved for different shows.
- Scripts can be triggered by one button (Just call up a script that you pre-programmed in vMIx)
- The volume faders are associated with the (AudioOn/Off) button below it. You can assign them to any input.
- You can hide the unused buttons if you wish
- Assign the vMix IP in the IP field (don’t add the port number)
- The program can be run on multiple computers at the same time. This is nice if you have different operators doing different functions.
- It will run on Wifi or LAN as long as you are on the same network as your vMIx computer
- The fields to the left of the buttons are simply text fields. You can put whatever you like in it. It’s just a reference for however you design your layout.
So here’s my first version. It's not perfect but feel free to try it and offer any suggestions. Here’s a link to the Windows and MAC versions:
https://www.dropbox.com/...VGAWBtTI9OeECDQ-8Ua?dl=0
Leave the folder intact for the Windows version as the externals that it requires are inside it.
I’ve installed it on an all-in-one PC Touchscreen and it seems to work quite well. That’s mostly the reason I wrote it…
cannot download the software
raugert
#25 Posted : Wednesday, January 9, 2019 12:14:34 PM(UTC)
raugert
Canada
This project has been replaced by the "vMIx Panel Builder". Download is available at:
https://forums.vmix.com/...Mac-Windows-Touchscreens
Joeboe
#26 Posted : Wednesday, January 9, 2019 11:35:45 PM(UTC)
Joeboe
The Panel builder replaced that control panel, and is WAY better.....user designed, buttons where you want them, sized to user likes, the Panel Builder is the best thing so far....I use it all the time, and it s beautiful....wish someone would teach me how to write code......
2 Pages<12
