seb666
#1 Posted : Monday, March 26, 2018 8:17:45 PM(UTC)
seb666
Hi Forum,
I recently tested "Unity Intercom" with vMix and think it's a fantastic solution for an easy wireless intercom. And the best: it has integrated Tally which works with vMix!
There is only one showstopper: vMix's API does only tell the actual input, which is in use via the <preview> and <active> tag. I'm using various Picture-in-Picture inputs with multiple sources and my main camera can be used in different inputs. "Unity Intercom" reads the values in preview / active and they are willed to adapt their use of the API. But vMix has to provide the information, which inputs are active in the Multiview input in preview or live. Is it possible to change the information in the XML tags used at the moment, that it would read eg <preview>2, 5, 12</preview> or to introduce new "multiview tags"?
Regards
Seb
P.S.: Here you can find some more information about Unity Intercom: http://www.unityintercom.com/unity3
