mgrayeb
#1 Posted : Friday, March 23, 2018 4:19:44 PM(UTC)
mgrayeb
I've searched the forum and found some sources for quality, cost-effective, animated lower-thirds, but are there also sources for the same in animated main titles (e.g. for show openers)?
I know that Titler Live is one option but I'm looking for ala carte options for animated main titles like I've seen with some of the animated lower thirds for vMix some folks have created and sell as off-the-shelf xaml solutions where the colors of the art and the text can be customized.
Any suggestions? Thanks.
NHT
#2 Posted : Monday, March 26, 2018 3:35:45 PM(UTC)
NHT
I'm not quite sure what you're after here, do you mean full screen backgrounds with text over the top?
mgrayeb
#3 Posted : Monday, March 26, 2018 4:44:42 PM(UTC)
mgrayeb
Yes, that's exactly what I mean. Thanks.
NHT
#4 Posted : Monday, March 26, 2018 4:58:46 PM(UTC)
NHT
Simply add an image or VT.
Add a text title.
Go to the settings cog of your background, select the multi-view sub menu and then your text file from one of the layer drop down menus.
And your done, hope that helps.
mgrayeb
#5 Posted : Tuesday, April 3, 2018 8:30:42 PM(UTC)
mgrayeb
Add a text title.
Thanks but I guess I wasn't clear on my question. vMix has an animated lower third title in the package of static titles that comes with the software. The animated lower third is called (I think) AnimatedNewsHD or something like that. It is in the Animated tab of the vMix Titles library.
I'm looking for a full-screen animation template (instead of a lower third animated template) and asking whether there are developers who sell those ala carte as templates (I've seen some who offer lower third templates ala carte but not main titles). Hope that makes sense.
Thanks.
JAIRODJ
#6 Posted : Thursday, April 5, 2018 4:18:48 PM(UTC)
JAIRODJ
Was thanked: 16 time(s) in 12 post(s)
Here they can help you, they make custom templates, write them
Custon Template graphics vMix
mgrayeb
#7 Posted : Thursday, April 5, 2018 6:31:14 PM(UTC)
mgrayeb
Thank you Jairodj.
