I use Album art of our radio broadcast system in the Title Overlay. By Image1 the pad (browse) to my image is C:\Test\NowPlaying.jpg This won't refresh. Anyone a suggestion?
By source I see txt and sheets etc. But I can't find info how to work with a picture that way. (Now playing text by source works great!)
You have been a member since:: 12/27/2012(UTC) Posts: 5,540  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
are you refering to using datasources ?
Yes I want to use datasources.
Thx! So I make an xml by Openoffice.... See attachement. I use insert>picture>NowPlaying.jpg
The xml doesn't seem to consist an picture. What's goes wrong? Because of this i can't find my xpath.
What is the file supposed to contain ? as is xml file is NOT usefull at all !
Ok, I see my fault.
Now it contains:
<root> <HeaderText> <HeaderText>Dan Testing</HeaderText> </HeaderText> <Image> <img src="file:///C:/Test/NowPlaying1.jpg"/> </Image> <BodyText> <p>This is a test of the body text<br /></p> </BodyText> <ShowLinkArrow>false</ShowLinkArrow> </root>
Xpath is /root/Image/img
This results in>>> src1 > file:///C:/Test/NowPlaying1.jpg
This gives text but no picture in preview (Title editor in Vmix)
Help! Thx
It should not be "file:///C:/Test/NowPlaying1.jpg" but "C:/Test/NowPlaying1.jpg"
Should have been clear from the link i gave previously
I already tried that. But this gives the same result. It loads text instead off a picture
are you sure you are trying to replace an image rather then a text field in the title ?
i tried your xml (corrected) and it woks ok
Thx for your reply. Yes I'm sure. See attachement. Text>>> text file with artist and song title Xml>>> picture of the album art The screenshot show a picture of album art this is because I put it in with the title editor (browse). After that I give the picture a pad in Vmix >>>xml file gerrit attached the following image(s):  vmix.jpg (444kb) downloaded 14 time(s).You cannot view/download attachments. Try to login or register.
have you tried to specify the collumn instead of auto ?
Yes. This works collumn is now src1
But one thing. When the next song plays the picture (NowPlaying1.jpg) is re-writen (same name). The picture in title Vmix doesn't refresh
It doesnt respond as there no real change (same filename), its the same data. I do not know the criteria on which datasource changes is based on I actually wonder why you would change the album image to the same name while i imagine they are all individual seperate items you can select based on te song or whatever criteria you are using. There is somewhere in this forum a title with script posted by Martin (vMix) that deals with reloading an image based on it being edited/updated edit: found it ; https://forums.vmix.com/default....osts&m=5025#post5025
I could work with different names. Artist or Song name or even time stamp. But the Xml file works with a hard route >>> C:\Test\Madonna.jpg next song is Micheal.jpg but the xml file doesn't now if I don't change it manual.
The whole point of the Datasources is the get UPDATES/CHANGES on data it contains. Would be bad practise to reload and redisplay , especially big files, just for the heck of it and loose focus on vMix's main purpose.
Think you rather need to look into properly changing your data collection approach.
