Instant Replay
Camera frame rate must match Replay Session Format
I would like to use four cameras for instant replay sources on my vMix Pro 20 software. I have a new rig that has lots of power and storage to support this. My camera setup for IR is as follows: Two cameras are PTZoptics 20x SDI that have been upgrated to NDI and I will try to use via NDI. I currently have these cameras set to 1080p60. Another two cameras are Canon XA25 that are set to 1080p59.94. When I try to add these four cameras, I get an error from vMix because the framerates are not exactly the same - 59.94 vs 60. I am hoping there is a way to get past this? Any tips/ideas would be most appreciated! I would really like to keep the 1080p60/59.94 setting. I am not a framerate expert by any means, but I did some research and I think that 1080p60 and 1080p59.94 are essentially synonyms. If so, is there a way in vMix to rename the framerate on two of my sources so that I can make vMix "happy" that both are the "same" and vMix will then allow all four sources into the IR session? Thanks, Bruce brewferg attached the following image(s): ![](/Themes/yafpro/icon_file.gif) vmix_ir.PNG (209kb) downloaded 6 time(s).You cannot view/download attachments. Try to login or register.
Joined: 8/22/2013(UTC) Posts: 92 ![Man Man](/Themes/yafpro/male.gif) Location: Rochester, NY Was thanked: 13 time(s) in 9 post(s)
Instant Replay
