Joined: 5/3/2016(UTC) Posts: 28 Location: United Kingdom
Trying to create a title using Title Designer. The text box is placed central in the graphics but when it displays it is right at the top of the graphics, moving text box makes no difference, how do I move it, see pictures. David-NBC attached the following image(s):  TitleD.png (102kb) downloaded 2 time(s). Wtitle.png (33kb) downloaded 2 time(s).You cannot view/download attachments. Try to login or register.
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
youve positioned a one line box in the middle and then I presume when you write two lines in the box is getting bigger upwards. if you're saying when you then adjust the positions it never changes in the play out, maybe once you've saved your changes in title designer you need to re-import the title in the input even though it's the same name
Barney Box Lane wrote:youve positioned a one line box in the middle and then I presume when you write two lines in the box is getting bigger upwards. if you're saying when you then adjust the positions it never changes in the play out, maybe once you've saved your changes in title designer you need to re-import the title in the input even though it's the same name Yes that's it you need to re-import the title in the input. Thanks David
