Feature Requests
Multicorder with IP cameras
Joined: 3/15/2018(UTC) Posts: 1  Location: Madison, NJ
Please allow VMix Multicorder to recognize IP-cam inputs.
Background - In order to simplify our installation and keep video latency to a minimum, we've been on internet protocol PTZOptics cams - now six - through a commercial grade network switch since we started using VMix. This choice had unintended consequences: a) eliminating the Multicorder feature from VMix; and b) minimizing the immediate value of NDI-HX.
We can't do post-production video processing if we can only save the program feed. Everything we do has to be edited on-the-fly, which works okay for some events, but not for more complicated, higher profile events. We don't really want to be in the post-production business, but our best clients demand that we at least give THEM the saved inputs so that they can farm it out to be edited.
Have you had any luck or response with this feature request? We are looking to do the same thing. Multi-corder with mixed capture card and IP-cam inputs
Joined: 11/23/2016(UTC) Posts: 330  Location: USA Thanks: 179 times Was thanked: 26 time(s) in 25 post(s)
With the next version 22 the recording will change entirely. Maybe a good chance that this will be possible by then.
Take a look at the vMix22 feature preview video. Look at it around 14 minutes in. Not sure if this is means IP cams could be supported??
Joined: 8/25/2018(UTC) Posts: 23   Location: Da OC, CA Was thanked: 1 time(s) in 1 post(s)
Feature Requests
