If i capture a 2160p signal that i crop into four 1080p virtual inputs what gives me the best quality when my output is 1080p: a 2160p or a 1080p preset?
Not sure I understand the question completely.
If you use vMix 4k you can have a 2160p input, and crop/zoom it down to 1080p.
If the project is set for 1080p then you have effectively 1:1 pixel ratio of source:output. The quality will be very good.
If you use vMix HD you can have a 2160p input, but it will always be scaled down to 1080p. Any attempt to crop/zoom it will result in the image softening.
mjgraves wrote:Not sure I understand the question completely.
If you use vMix HD you can have a 2160p input, but it will always be scaled down to 1080p. Any attempt to crop/zoom it will result in the image softening. I have vMix 4K. The question is what gives better quality scaling: - Put 2160p camera into 1080p preset with 1080p external output and encode to 1080p (vMix scales?) - Put 2160p camera into 2160p preset with 1080p external output and encode to 1080p (FMLE or FFMPEG scales?)
I do believe that this is something you can answer for yourself. Setup a test scene and try both approaches.
I'd be curious to know how the load (CPU/GPU) differs. If you're using hardware encoding you might find that scaling at the output stage is less burdensome.
