How to Change Color Scheme of Static Lower Third in vMix Title
Thanks: 86 times Was thanked: 7 time(s) in 7 post(s)
Is there a way to change the color scheme of one of the static lower thirds that comes with vMix? I searched the forums and videos but can't seem to find it. I'm not trying to change the text color; instead, the color of graphic itself.
Thanks.
for some of the titles the colors can be changed in the xaml code of the title , for someothers it is replacing the images
doggy wrote:for some of the titles the colors can be changed in the xaml code of the title , for someothers it is replacing the images Ok thanks. I've brought "Title 6" xaml file into the vMix Title Designer. Is that where I'd edit it? How do I access the code to make the color changes? When I try to right-click on the Input of the Title File and choose XAML properties, I'm not able to open the properties. Thank you.
I assume you meant the "NewsHD6" title ? one can not change the color in the title designer but can the opacity you can do this with a regular texteditor (notepad for example) and change the colorvalues of the rectangles in this case the GradientStop color Code:<Rectangle Height="201" HorizontalAlignment="Center" Margin="0,879,0,0" Name="Rectangle1" Stroke="Black" VerticalAlignment="Top" Width="1920" Opacity="0.8" StrokeThickness="0">
<Rectangle.Fill>
<LinearGradientBrush EndPoint="0.5,1" StartPoint="0.5,0">
<GradientStop Color="#FF4B99A7" Offset="0" />
<GradientStop Color="#FF007900" Offset="1" />
</LinearGradientBrush>
</Rectangle.Fill>
</Rectangle>
 2 users thanked doggy for this useful post.
doggy wrote:I assume you meant the "NewsHD6" title ? one can not change the color in the title designer but can the opacity you can do this with a regular texteditor (notepad for example) and change the colorvalues of the rectangles in this case the GradientStop color Code:<Rectangle Height="201" HorizontalAlignment="Center" Margin="0,879,0,0" Name="Rectangle1" Stroke="Black" VerticalAlignment="Top" Width="1920" Opacity="0.8" StrokeThickness="0">
<Rectangle.Fill>
</Rectangle.Fill>
</Rectangle>
Thanks, but that's not the one I'm looking at. It's simply called "Title 6" and it's down toward the bottom of the titles folder. I saw your post on a different thread on the forums suggesting Visual Studio Community program to access the Blend editor. I downloaded that program and then I opened the .xaml file (*I think*) for the "Title 6" title in Visual Studio Community. Here's what I see as the code: <UserControl x:Class="Title6" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006" xmlns:d="http://schemas.microsoft.com/expression/blend/2008" mc:Ignorable="d" d:DesignHeight="1080" d:DesignWidth="1920" Width="1920" Height="1080" xmlns:my="clr-namespace:vMixTitleLibrary;assembly=vMixTitleLibrary"> <Grid> <Canvas> <Image Source="Title6.xaml.png" Width="1920" Height="1080" /> <my:TextBlockDesign Canvas.Left="284" Canvas.Top="817" Height="172" Name="Heading" Width="1379" Text="HEADING" FontWeight="Bold" FontSize="72" Fill="White" FontFamily="Tw Cen MT Ex"></my:TextBlockDesign> <my:TextBlockDesign Canvas.Left="288" Canvas.Top="930" Fill="#FF174776" FontSize="52" FontWeight="Bold" Height="105" Name="Description" Text="DESCRIPTION" Width="1375" FontFamily="Tw Cen MT" /> </Canvas> </Grid> </UserControl> What are the color numbers in the above code, and how do I find alternate color numbers to plug in? I was using a Hex Color Chart but it looks like the "Fill" number above #FF174776 is longer than a HEX number? Also, how did you access the xaml code you pasted in your reply above and how did you make the update you posted? Thanks for your help.
title6 has an image as background !
doggy wrote:title6 has an image as background ! Ok so I can't change that color since it's an image, if I understand you correctly. Is there a way to know that up front by looking at it in the Titles folder, or can you only tell that after opening it in Visual Studio? Just trying to understand when and how I can change the graphic colors on a title. Assuming it's a title without an image in the background, once you open it in Visual Studio, I'm assuming you make changes to the color numbers. Then how do you view the updated image in Visual Studio to see if the changes look right? Thanks.
#FF174776
first 2 characters (FF) represent the tranparency , in this case none
Quote:Is there a way to know that up front by looking at it in the Titles folder in the folder you can see there is a title6.xaml.png which is the background imag one could edit or replace also in the code there are no rectangles defined but rather a image source Code:<Image Source="Title6.xaml.png" Width="1920" Height="1080" />
doggy attached the following image(s):  title.JPG (60kb) downloaded 11 time(s).You cannot view/download attachments. Try to login or register.
doggy wrote:#FF174776
first 2 characters (FF) represent the tranparency , in this case none Ok great. I think I've got it now. Thanks so much!
doggy wrote:Quote:Is there a way to know that up front by looking at it in the Titles folder in the folder you can see there is a title6.xaml.png which is the background imag one could edit or replace also in the code there are no rectangles defined but rather a image source Code:<Image Source="Title6.xaml.png" Width="1920" Height="1080" />
Makes sense now; thank you!
Quote:Assuming it's a title without an image in the background, once you open it in Visual Studio, I'm assuming you make changes to the color numbers. Then how do you view the updated image in Visual Studio to see if the changes look right? Thanks. its a visual editor, you can change the colors of the object by picking a color and finetuning it with sliders etc and wil instantly see the change in your object doggy attached the following image(s):  color.JPG (37kb) downloaded 3 time(s).You cannot view/download attachments. Try to login or register.
<Rectangle.Fill>
</Rectangle.Fill>
</Rectangle>
One other question: Once I've modified the colors in the .xaml file using Visual Studio Community, is there an easy way to view the changes in Visual Studio Community before saving the file to my folder? Right now the way I'm editing the code in Visual Studio Community is I'm going to File > Open > File, and then navigating to the .xaml file in the Titles folder for vMix. Once I've changed the color numbers in the code, how do I view the modified file as an image within Visual Studio? Thanks.
doggy wrote:Quote:Assuming it's a title without an image in the background, once you open it in Visual Studio, I'm assuming you make changes to the color numbers. Then how do you view the updated image in Visual Studio to see if the changes look right? Thanks. its a visual editor, you can change the colors of the object by picking a color and finetuning it with sliders etc and wil instantly see the change in your object I think I might only be in Visual Studio -- not in the Blend tool (not sure how to get to that?). Pleas see attached. I really appreciate your patience and help! mgrayeb attached the following image(s):  visual studio community screenshot.jpg (331kb) downloaded 23 time(s).You cannot view/download attachments. Try to login or register.
Quote:Right now the way I'm editing the code in Visual Studio Community is I'm going to File > Open > File, and then navigating to the .xaml file in the Titles folder for vMix. Once I've changed the color numbers in the code, how do I view the modified file as an image within Visual Studio? you can not directly from just the file here, mostly one would have the file in project wich would then have a design view also
if you create a wpf user control project you can then copy/replace the Xaml code in the xaml window and then view the design in the design window (and make visual changes to your design)
mind you if you take the code from one of the vMix titles you will need to add a reference to the vMixTittlelibrary.dll
doggy wrote:if you create a wpf user control project you can then copy/replace the Xaml code in the xaml window and then view the design in the design window (and make visual changes to your design)
mind you if you take the code from one of the vMix titles you will need to add a reference to the vMixTittlelibrary.dll Ok and sorry I'm so dense and have so many questions; I'm brand new to vMix, and don't have programming knowledge so I've not used Visual Studio/Blend before. I added the reference file as you indicated, and I've been able to bring in a NewsTitle6 from vMix. Please see attached screenshot. I tried clicking on the tools on the left side of the screen (or the greyed-out tools at the top) but not sure how to change the colors in the title's graphics. Can you please point me to any info that I can learn on how to do that? Thank you. mgrayeb attached the following image(s):  blend screenshot 1 031118.jpg (283kb) downloaded 19 time(s).You cannot view/download attachments. Try to login or register.
open property window (F4)
Mind you this is a vMixforum I advice to brush up on how to use other software by googeling for tutorials etc
Understood Doggy. I had been searching via Google and Youtube but was unsuccessful. Again, thank you so much for your help; I really appreciate it.
