Hardware Compatibility
Box with 4 SDI inputs to laptop by USB 3.0
I looking for a box with 4 SDI inputs to go to the laptop by USB 3.0. I can't see nothing about this.
If that item exists could i see (preview) the all cameras in VMIX?
jaialai wrote:I looking for a box with 4 SDI inputs to go to the laptop by USB 3.0. I can't see nothing about this. If that item exists could i see (preview) the all cameras in VMIX? Unless you were working at SD resolution, USB3 doesn't have enough bandwidth for four uncompressed video signals, which I guess is why no-one makes such a device in an age where HD is the expected norm. Technically, a device could be made which uses lossy hardware compression to reduce the data-rate sufficiently to handle four streams of HD over USB3, but if using (uncompressed) SDI sources, why would people want to lower the quality by using such a method? It is better to use a Thunderbolt connection to an external PCIe expansion chassis fitted with a quad SDI capture card from the likes of AJA, Blackmagic, Magewell or Yuan.
 2 users thanked zenvideo for this useful post.
Thanks for your reply. Yes i use hd video.
zenvideo wrote:It is better to use a Thunderbolt connection to an external PCIe expansion chassis fitted with a quad SDI capture card from the likes of AJA, Blackmagic, Magewell or Yuan. Agreed! Could you recommend a Thunderbolt 3 PCIe card?
Joined: 11/21/2017(UTC) Posts: 124  Location: Philadephia, PA Thanks: 31 times Was thanked: 14 time(s) in 9 post(s)
