3rd Party Software and Development
Free items - Lower Thirds, Plug-Ins, Control apps, Designs ...
Was thanked: 8 time(s) in 4 post(s)
 1 user thanked miljansoax for this useful post.
@ miljansoax
Very cool! Thanks for sharing.
You have been a member since:: 12/27/2012(UTC) Posts: 5,530  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Very Nice!
one question : is it intentional that the included logo doesnt load directly with the title ?
@ doggy
You can change logo also.
@ miljansoax
i understand that, was just wondering as it looked to be an initial part of the title, hence save time loading the title and not to set the logo each time
Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
miljansoax, thanks for the lower third is really nice, what you used to create this graphic animation
@ Marvin ... as Doggy explained in last Post, Microsoft Blend.
@ miljansoax
While i also would create titles as a .dll file when complex code is involved to handle desing changes by data changes i am wondering why this is done here rather than a regular xaml file (with the images included in the folder) . the "problem" is when you want to make small changes to the background image for example and recompile it to a .dll you will have to close vmix completely in order to reload the .dll properly with the changes applied. As one is creating it in Blend anyway why not use rectangles or borders and color those in xaml rather than images? Will save you having to use another drawing program to redesign or tweak those "backgrounds"
Code:<Canvas Height="150" Margin="212.948,0,318.316,207.896" ClipToBounds="true" VerticalAlignment="Bottom">
<Rectangle x:Name="rectangle" RadiusY="12.552" RadiusX="12.552" RenderTransformOrigin="0.5,0.5" Height="96" Canvas.Left="-45.515" Canvas.Top="26" Width="1404">
<Rectangle.Stroke>
<LinearGradientBrush EndPoint="1.015,0.853" StartPoint="0.865,0.095">
<GradientStop Color="Black" Offset="0.288"/>
<GradientStop Color="White" Offset="1"/>
</LinearGradientBrush>
</Rectangle.Stroke>
<Rectangle.RenderTransform>
<TransformGroup>
<ScaleTransform/>
<SkewTransform AngleX="-27"/>
<RotateTransform/>
<TranslateTransform/>
</TransformGroup>
</Rectangle.RenderTransform>
<Rectangle.Fill>
<LinearGradientBrush EndPoint="0.5,1" MappingMode="RelativeToBoundingBox" StartPoint="0.5,0">
<GradientStop Color="#FF1969C7" Offset="1"/>
<GradientStop Color="#FF196AC7" Offset="0.559"/>
<GradientStop Color="#FF3699DD" Offset="0.557"/>
</Rectangle.Fill>
</Rectangle>
</Canvas>
doggy attached the following image(s):  imgxaml.jpg (41kb) downloaded 44 time(s).You cannot view/download attachments. Try to login or register.
@ doggy I'm using sometimes images, sometimes rectangles. Sometimes you can't draw with vectors what you want to show. But not in this case, of course. Sample with rectangles: Lower Third Sample Preview
miljansoax wrote:@ Marvin ... as Doggy explained in last Post, Microsoft Blend. thanks so much you did a great job
