can virtual set support different camera angle?
I found there 4 camera angle only can be set in different zoom, not angle, how can I add a new camera angle in virtual set?
@ bh1054010 You are correct that the Virtual Sets in vMix are single camera with 4 Zoom settings or "angles" with respect to "field of view". Using another camera from a different position or "angle of view" would require a second Virtual Set that is looking from that camera position (same set design from a different perspective). AFAIK, None of the included sets in vMix have a different perspective view of the same set, but many of the Sets designed by VirtualSetWorks.com do, should you care to explore those. Having said all that, you can certainly add a second camera Input to any Virtual Set in vMix within its MultiView feature (which is essentially what Virtual Sets are using in the first place), just be aware of what Overlay channel is being used for what and add your second camera appropriately (not sure why you would do this, but it is possible). Ice
Joined: 4/18/2016(UTC) Posts: 223 Location: United Kingdom
Thanks: 33 times Was thanked: 37 time(s) in 31 post(s)
There are virtual sets that support multi-angle. PTZO Youtube
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
+1 live studio where you have a real background and want different angles.
at the end of the day the roaming presenter can sit down and review some stuff, but the projects already massive so it would be awesome if we just had all 4 web cams in a live studio single input, we could then add it to our end of day project tab and for several reasons that would streamline things and keep the set up clean
