Joined: 9/13/2016(UTC) Posts: 118   Location: Ukraine Thanks: 6 times Was thanked: 5 time(s) in 4 post(s)
There is a task - 2 inputs of vMix Call (dynamic) to broadcast, but sometimes there is a non-standard format of the frame that needs to be increased. Moreover, on this video you need to add a dice - from where the inclusion occurs. So - I create a vMix Call connection, add an input (color with transparency) in which one layer is vMix Call, the second die - that's all good (The composite input is used as the main). But then I add the resulting result to the composite multiskrin, where I need to crop it. And here's the trouble - scaling works, positioning too, and crop does not work! How to be ??? In the video as much as possible tried to show this problem.
Joined: 3/7/2012(UTC) Posts: 2,683  Location: Canada Thanks: 33 times Was thanked: 512 time(s) in 480 post(s)
@ Murchik
It would appear you are trying to crop the Virtual Image of a Virtual Image, which can't be done in vMix as you are already 2 layers deep. This is for performance reasons as vMix does not pre-render doubly composited Inputs (MultiView of a MultiView) You can crop the original Image or the Virtual Image, but not the Virtual of the Virtual. The Zoom works because that is the size of the screen, but the crop will not because the image is not really there or at least in that space, it's further behind, in other words, the crop settings are there, they are just not being applied to anything. To prove my point, simply replace the In 4 Input in Overlay 2 with the original Call 111 Input and you will see the crop works fine. I hope that helps to explain it a little.
sad ... very short of one level of crop
