Correct syntax for DataSourceSelectRow Web API/Script?
I am trying to find the correct call for Web Scripting for DataSourceSelectRow. Using a regular shortcut with the Value "matcher-odds,,0" (to select Index 0 with no table specified for a DataSource named "matcher-odds" works just fine. But a web API to http://192.168.1.xx:8088/?Function=DataSourceSelectRow&Value=matcher-odds,,0 does not. Neither does Web Script Function=DataSourceSelectRow&Value=matcher-odds,,0 Looking into https://www.vmix.com/help20/DeveloperAPI.html there is no mention of DataSourceSelectRow in the "Value", "SelectedName", "SelectedIndex" sections. And if any of those would be applicable there is no corresponding "SelectedTable" section. Any ideas? Thanks.
From memory but the table name is required....
127.0.0.1:8088/API/?Function=DataSourceSelectRow&Value=gsheets,Sheet1,2
This one drove me nuts a few months ago.
Joined: 1/13/2010(UTC) Posts: 5,311  Location: Gold Coast, Australia Was thanked: 4711 time(s) in 1615 post(s)
Be careful when using web addresses with symbols like , # etc as these need to be correctly "encoded" to work as a url value. This is not only the case with vMix, but with any web based APIs. This is a handy tool that can be used to encode the values correctly: https://meyerweb.com/eric/tools/dencoder/Type in just the text you want to set as the Value, not the whole url. So "Excel/CSV,Sheet1,5" would become Excel%2FCSV%2CSheet1%2C5 And in turn the whole URL would be: http://localhost:8088/API/?Function=DataSourceSelectRow&Value=Excel%2FCSV%2CSheet1%2C5
 3 users thanked admin for this useful post.
Thanks-- this explains why with unencoded urls it works on some browsers but not others-- which was confusing.
admin wrote:Be careful when using web addresses with symbols like , # etc as these need to be correctly "encoded" to work as a url value. Thanks! I forgot that for the Web API call but missed it was necessary for values when using Scripts too. Put differently, that comma was a "special character".
