Recorded Footage Very Pixelated, How to Fix?
Welcome to vMix and the Users' Forum. First, check your Recording settings to make sure you are recording 1080p video not a lower resolution. Next, make sure you vMix desktop resolution is 1080p. Next, consider using the vMix Desktop Capture app on the Mac to transfer video from the Mac to your PC over your network connection. I think you'll get a better image. Use this link to get the Mac version of the app: http://cdn.vmix.com/down...DesktopCaptureMacNDI.zipGood luck! - Tom
 1 user thanked sinc747 for this useful post.
Joined: 3/3/2018(UTC) Posts: 1 Location: Dallas, Texas
Thank you Tom, that corrected my issue!
