Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
Hi, is anyone have create a animate lowerthird in Adobe AE, and add title in vmix? it can be done? thanks every body for your answer and help
Yes,I can do it
XAML Definition of text animation + AE subtitles title + Trigger setting
Joined: 8/21/2015(UTC) Posts: 324 ![Man Man](/Themes/yafpro/male.gif) ![Canada Canada](/Content/images/flags/CA.png) Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
@540144407
Can you explain the process in detail or in a video?
thx
Joined: 10/13/2012(UTC) Posts: 1,162 ![Australia Australia](/Content/images/flags/AU.png) Location: Melbourne Thanks: 220 times Was thanked: 199 time(s) in 181 post(s)
NDI Is also a good choice
The drawback is that you need to control 2 software
Thanks so much, is there other way I dont have adobe CC any tutorials?
