Joined: 5/27/2017(UTC) Posts: 93   Location: Greater St Louis Area Thanks: 67 times Was thanked: 20 time(s) in 13 post(s)
I was just going through my logs from last night's production and found a ton of:
20.0.0.55 - ExecuteTriggers - 2/22/2018 6:45:32 PM
======================================== vMix.VMIXException: Invalid Parameters. at gzzzzzd.zq(Shortcut a, Boolean a) at vMix.InputTrigger.Execute() at izzzzzw.i(InputTriggerType a) ========================================
and also...
======================================== Skipped due to thread mismatch ========================================
Is there a more verbose logging setting I can configure so better understand what I need to change?
Chad
Joined: 1/13/2010(UTC) Posts: 5,373  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
The second error is nothing to worry about, just an alert that vMix avoided a potential error by closing the VST plugins in a different way. The first means one of the triggers has an empty or invalid value. In this case it was SetMultiViewOverlay with a blank Value.
Martin vMix
