Feature Requests
Push replay video to social media during broadcast
Ability to connect Vmix Replay to social media Facebook,Twitter, YouTube and SnappyTv to upload selected replay clips in the background while streaming to main source Eg Upload to Twitter a Slam Dunk with in the 1 minute of it happening during play and replay on screen.
 3 users thanked corporatejames for this useful post.
YES! +1 It would be great if something could allow me to select a portion of the replay then automatically upload and post to Facebook/Twitter. Then a social media operator could share video clips during a live stream. As mentioned, Snappy TV does this, but they are expensive so it would be great for software to do it internally.
Thanks: 23 times Was thanked: 13 time(s) in 10 post(s)
replay already has an export function. setup a ITTT (If this then that) rule to auto publish the contents of your export folder.
tnorrell wrote:replay already has an export function. setup a ITTT (If this then that) rule to auto publish the contents of your export folder.
Thanks. Yeap I export them as well. But my feature request is have this built into vmix replay as a social tool to post selected clips during stream and possible default tag line and hashtag. Maybe someone has to control the message. Have not fully used replay yet as been testing ready for next season and thought this would be killer feature. Could have a third party app available that watches a folder and uploads from there but I will have have search to find out.
We use video delay as replay as most people do. Only allowing AVI files as the delay clip format makes uploading very difficult because of size. Would be nice to encode mp4 OR have an option to transcode and auto post to social media.
Thanks: 39 times Was thanked: 39 time(s) in 35 post(s)
Absolutely YES! I really need that feature!
Thanks: 8 times Was thanked: 6 time(s) in 6 post(s)
Joined: 4/6/2016(UTC) Posts: 84  Location: Sweden Thanks: 25 times Was thanked: 18 time(s) in 13 post(s)
Could this be achieved by having the LIST input accept a folder as well as individual files? So the idea is that as you add a video file to the "watched" folder it adds it to the list. That way a 2nd instance of vMix, perhaps on the same or a 2nd PC can handle the uploading to Facebook (or anywhere else) as a stream. By using the list function, it then allows an operator to make decisions about what is streamed.
Thanks: 211 times Was thanked: 13 time(s) in 12 post(s)
Thanks Given: Was thanked: 7 time(s) in 4 post(s)
Joined: 8/2/2013(UTC) Posts: 1,098   Location: Fairhope, Alabama USA Thanks: 587 times Was thanked: 202 time(s) in 168 post(s)
Joined: 8/3/2015(UTC) Posts: 325 Location: Chicago, IL
Joined: 6/6/2017(UTC) Posts: 40 Location: Mississippi, United States
Thanks: 8 times Was thanked: 2 time(s) in 2 post(s)
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
ask wrote:Could this be achieved by having the LIST input accept a folder as well as individual files? So the idea is that as you add a video file to the "watched" folder it adds it to the list. That way a 2nd instance of vMix, perhaps on the same or a 2nd PC can handle the uploading to Facebook (or anywhere else) as a stream. By using the list function, it then allows an operator to make decisions about what is streamed. +1+1 add replays to the list feature, requested this a while ago and it would be incredible if the folder you store them in is a playable list
Feature Requests
