I believe I discovered a bug.
Thanks: 12 times Was thanked: 3 time(s) in 3 post(s)
I am using the scrolling title.
I have it saved as a separate input.
Whenever I bring that into a multiview tab.
It defaults back to the jibberish text - whereas it should logically stay as the text that I had put in it - but instead it defaults back to the jibberish text.
I want it to be the same scroll in multiple inputs - but every time I do - it goes back.
Is that a bug - or is there a reason for this? and if so - how do I make it not go back - since it changes the original input - and every other instance of it.
Joined: 8/3/2015(UTC) Views messages in topic : 323 Location: Chicago, IL
I cant replicate the problem here. I added a camera input into a fresh vMix instance. Created a "TickerHD" Title, changed the text and closed the window. Brought that input into My camera Input through Multiview Position 1 and the updated text is displayed.
Am I doing something different than you?
EDIT: Creating multiple versions of that camera input, I have changed the position of the title and updating the original title updates all instances of the Multiview embedded versions. Try with a blank session and 2 inputs to see if you get the same result...
So weird. It keeps happening here
Are you using the most recent version? And have you tested on a fresh instance of vMix with only 2 inputs? Maybe post a screen shot of your setup or give some more details of your settings.
Joined: 11/23/2016(UTC) Posts: 330  Location: USA Thanks: 179 times Was thanked: 26 time(s) in 25 post(s)
Long shot. Did you type in the titles by hsnd or did you copy and paste the text from a program like Microsoft Word. (This is just a guess — but maybe it’s what is causing the issue.....)
First time was a copy and paste. -
But since then - - by hand
and I deleted and then re-created the input - and it still happens.
You’re probably going to have to provide some more detailed information. I have asked before, and it’s my first stop when I have problems with my setup. But, have you recreated this on a Blank vMix instance. Not one where you removed inputs, but a clean first run. Just to be sure.
