Can't stream to YouTube AND Facebook (Solved)
Joined: 2/18/2014(UTC) Posts: 1,845 Location: Stockholm
Just noticed that I got an error attempting to stream, using Custom Presets, to YouTube and Facebook. Each preset works individually but not in combo. Worked just fine a few days ago. Using 20.0.0.46, maybe the most recent update contains a fix, but I can't try that right now. Anyone else noticed this?
Joined: 1/23/2018(UTC) Posts: 16  Location: Poland Thanks: 6 times Was thanked: 2 time(s) in 2 post(s)
richardgatarski wrote:Just noticed that I got an error attempting to stream, using Custom Presets, to YouTube and Facebook. Each preset works individually but not in combo. Worked just fine a few days ago. Using 20.0.0.46, maybe the most recent update contains a fix, but I can't try that right now. Anyone else noticed this? You need configurate like this: for better quality: first server is youtub 1080p
second server is custom for Facebook 720p
 1 user thanked Brutuss for this useful post.
Thanks Brutuss, But as I wrote I did indeed use the Custom settings, and each stream worked individually but not when I tried both at the same time. I am afraid there is something going on at Facebooks end.
I believe this is by design, facebook terms of service state that video streamed to it cannot be streamed elsewhere.
I regard this issue as solved after trying again and finding that now it works streaming to both YouTube and Facebook using Custom RTMP. Maybe it was a temporary hickup...
 1 user thanked richardgatarski for this useful post.
