cg4162345
#1 Posted : Wednesday, February 21, 2018 12:32:23 AM(UTC)
cg4162345
Was thanked: 7 time(s) in 3 post(s)
Here is an app that provides a REST API and remote web controller access for vMix.
Download
GitHub Project
Full documentation
Features
* Well-documented API for vMix that's built with REST principles in mind.
* Remote access to the REST API and vMix's native Web Controller.
* Easily get inputs, overlays, transitions, and send actions to a running vMix instance.
* Standalone Windows executable that exposes the REST API.
* Runs alongside vMix's existing XML-based API.
Installation
1. Download the latest Windows release
2. Run vMix and enable the Web Controller.
3. Open the included config.yml file in a text editor and update it with your Web Controller URL. Optionally enable settings for remote API access and remote Web Controller access.
4. Run the vMix REST API and you'll be given the local base URL to your REST API (and also remote access URLs if you enabled remote access). Check out the examples to get started or read the full API documentation.
thanks 5 users thanked cg4162345 for this useful post.
Stavlin on 2/21/2018(UTC), vijay6672 on 2/21/2018(UTC), kjones9999 on 2/21/2018(UTC), DWAM on 2/22/2018(UTC), Vladis on 10/7/2020(UTC)
#2 Posted : Thursday, February 22, 2018 4:11:12 AM(UTC)
Was thanked: 794 time(s) in 589 post(s)
Good job. Congrats Curt
projer
#3 Posted : Thursday, March 23, 2023 5:17:36 AM(UTC)
projer
Mexico
Woo increible!!
Seria genial que vmix integrara esta función de manera nativa
