Feature Requests
Changing Input Stream - Settings should be filled out
Hello.
I have to adjust the settings (Buffer, Adress) of an Input-Stream really often. It would be nice that when you configure a stream and then push change, that the Settings are already filled out (StreamType, URL, Buffer,..) and the right Input-Stream is marked in the list.
Thanks, Jimmy
Thanks: 1 times Was thanked: 3 time(s) in 3 post(s)
I second that. It's often that an input needs to be changed, but it's frustrating, that you have to go through all settings, if just one needs to be changed.
Thank
Feature Requests
