3rd Party Software and Development
Function AudioOn does not always put audio on
I'm currently using Vmix 20.0.0.52 x64 and uses the TCP api to control VMix.
When I want to play a video (a mp4 file) I send the following commands (This is an output of our script with the timestamps) : 19/02/2018 13:54:26:391 'FUNCTION AddInput Value=Video|M%3a%5csounds%5c00009%2eMP4' 19/02/2018 13:54:27:257 'FUNCTION CutDirect Input=35' 19/02/2018 13:54:27:472 'FUNCTION AudioOn Input=35' 19/02/2018 13:54:27:688 'FUNCTION AudioOff Input=Pgm' 19/02/2018 13:54:27:892 'FUNCTION AudioOn Input=Recbus' 19/02/2018 13:54:28:101 'FUNCTION AudioOff Input=Local'
We've put smalls breaks between each command (200 ms) because we noticed that sometime Vmix did not react to the command (the Vmix answers OK, but do not execute the command). From time to time the audio is not switched on (FUNCTION AudioOn Input=35), whereas the file has some audio.
Did you already noticed this behaviour ? Can it be linked to the fact the the audio is created (using AddInput) ?
