iamralphsutton
#1 Posted : Tuesday, February 20, 2018 8:32:10 AM(UTC)
iamralphsutton
I have been toying w vmix for a year- and I am finally ready to start actually using it for our productions.
Leaving xSplit behind.
What are your layouts for the tabs.
I am trying to map out the most logical layout for my stuff.
Also - is there a way to get an alphabetical list of your inputs? Or is it only in the order you put it in?
and the easiest way to quickly add TEXT on to a screen - is only the 2 input TEXT one - that you need to clear the 2nd text right?
Barney Box Lane
#2 Posted : Tuesday, February 20, 2018 9:39:48 AM(UTC)
Barney Box Lane
tabs - base layer
content
replays
divide your project into the three key blocks you need so they all hold a fairly even amount, leave the junk inputs you never touch during a broadcast unassigned and they will be in all (the grey tab)
inputs are in order and your commands are assigned to the input number ie on completion- cut to input 11adverts... if you move your input11adverts it will cut to whatever is in input11.
Seperate note, you can rename the inputs in the settings / general / click on the title, for more organisafiying.
not sure what you mean with the last question but remember when sorting the project to put things you don't want to clash on the sane overlays
and lastly set up two projects - clean and demo.. in the demo just go nuts don't worry about the mess and just see what everything does and almost try and break your set up (what I call clashes) as you slowly construct your filtered version in your clean set up.
The aim is to get rid of the 'hops' amount of buttons you have to press to execute the task right down to getting your equipment set up in the least amount of steps. Vmix is the best broadcasting software and with the triggers and automation if you spend the time you can do anything you want with it )
