kjones9999
#1 Posted : Sunday, February 18, 2018 3:49:40 PM(UTC)
kjones9999
Hi all.
This is a simple and probably useless update to some timers I created a while back.
The intent is to allow you to make an API web call at a specific time.
There are two versions -- one that notifies you the call has been made (note it doesnt look at vmix responses), and one that works just in the background "invisibly".
To use, extract the files. Double click one of the program files. Press CTRL+Windows Key and A and fill out the info.
Be sure to paste in a properly formed API URL. Once submitting, you may close all windows. You may run multiples of the program, but you must reopen a new program each time, You will note icons in the system tray. if you want to close the program, right mouse click on red icon in tray and choose exit.
You may get a message because its not signed- It is safe. It should work on any machine on the network. 64 bit only.
File Attachment(s):
timerAPIutility.zip (1,095kb) downloaded 314 time(s).
thanks 10 users thanked kjones9999 for this useful post.
avsoundguy on 2/18/2018(UTC), Stavlin on 2/20/2018(UTC), vijay6672 on 2/21/2018(UTC), sinc747 on 3/3/2018(UTC), Reinaldo on 8/11/2018(UTC), AgentPete on 11/22/2018(UTC), buhdan on 1/24/2021(UTC), TinyBear on 3/6/2021(UTC), studiodelta on 8/26/2021(UTC), nikosman88 on 2/8/2022(UTC)
Guest (4)
