5 Pages<1234>»
#21 Posted : Saturday, January 20, 2018 5:41:42 AM(UTC)
Rank:: Advanced Member
In order to use the MultiState widget, both vMix must have an identical configuration on all aspects: inputs, shortcuts and so on...
Everything triggered from UTC must match on all vMix hosts.
Guillaume
Element III
#22 Posted : Monday, January 29, 2018 12:19:42 PM(UTC)
Element III
Guillaume
Hi
i dont really now how its work i add the multi state widget, then put the adress of my second vmix and its not show me the xaml file from this one but if i open an other utc windows and put the adress it show me the xaml file so i cant switch my score on both vmix in only one utc ! Do you know why ?
Element III
#23 Posted : Friday, February 9, 2018 8:39:01 AM(UTC)
Element III
Hi again i see on youtube some people who add the vmix output video in Vmix UTC how did they do ?
Thx :)
zenon
#24 Posted : Sunday, February 11, 2018 9:58:47 AM(UTC)
zenon
with UTC is there a way to do external command like dos shell command or similar, I would like to send some external command also when something is triggered in Vmix.
thanks
Dominik
rudyengels
#25 Posted : Sunday, February 11, 2018 11:20:32 AM(UTC)
rudyengels
Was thanked: 25 time(s) in 18 post(s)
Thx :)
Do you mean this?
Cpilcher
#26 Posted : Sunday, February 11, 2018 1:40:14 PM(UTC)
Cpilcher
Looks like I need to revisit this software... Oh the possibilities.
Element III
#27 Posted : Tuesday, February 13, 2018 10:41:17 AM(UTC)
Element III
rudyengels wrote:
Thx :)
Do you mean this?
Hi yes thats exactly what i meant :) i tried to download the new utc with the ndi dll but its still not working i got the different output but when i click one just nothing happened :/
#28 Posted : Tuesday, February 13, 2018 4:21:08 PM(UTC)
No. UTC only triggers vMix
Element III
#29 Posted : Friday, February 16, 2018 5:39:46 AM(UTC)
Element III
If someone can help it will be very cool i tried on two differents computer vmix utc monitoring with ndi i see my source when i put the widget external data but when i click on the source just nothing appear ... That make me crazy, 3 days im on it ^^
Thx
Slimus
#30 Posted : Friday, February 16, 2018 6:27:52 AM(UTC)
Slimus
Hello i'm neebie,
i need to manage score and ranking for archery compitition like link below, is it possible with UTC ?
#31 Posted : Friday, February 16, 2018 11:14:02 AM(UTC)
Hi
using vMix Title Designer, vMix datasource and UTC, everything is possible. It's just a matter of work, persistence and creativity. Not easy for a newbie though but if you really want to do it, you surely can.
Guillaume
monamiga on 11/18/2018(UTC)
mtregael
#32 Posted : Sunday, February 25, 2018 4:27:38 PM(UTC)
mtregael
I have tried "Howto use vMix UTC as a Remote and Independent Switcher for External2" but the NDI widget is always black.
It display the sources list, but when i switch on one of them, nothing appears.
Here is attached a screenshot where you can see vMix working, NDI Video monitor working and UTC. As we can see, the NDI source list is updated... but there is no picture.
Any idea ?
mtregael attached the following image(s):
#33 Posted : Sunday, February 25, 2018 4:51:44 PM(UTC)
Salut
as-tu correctement configuré tes sorties NDI dans les settings ?
Quoiqu'il en soit, cette utilisation de vMixUTC est fortement recommandée sur un poste distant, pas le même ordi que celui de vMix...
Tiens-nous au jus
Guillaume
JAIRODJ
#34 Posted : Thursday, March 15, 2018 11:17:45 AM(UTC)
JAIRODJ
Was thanked: 16 time(s) in 12 post(s)
Hi, I've learned a lot to use UTC watching your tutorials.
It is possible that you teach us to use UTC with data source, my intention is to send data from excel to UTC.
Also if you can create a tutorial on how to use UTC with scripts, the native functions of UTC, condiction, conditionend, setvariable, etc., are functions that are there but you do not know how to use them.
I appreciate your help and what you have already done for us creating several tutorials before.
Good day.
thanks 1 user thanked JAIRODJ for this useful post.
omo on 4/2/2022(UTC)
#35 Posted : Sunday, March 18, 2018 4:57:36 AM(UTC)
Hi and thanks Jairodj!
Excel to UTC is not possible directly. UTC can only use XML.
I found it easier to use vMix datasources and just control them from UTC.
As of conditions in UTC, I have not worked much with them so far, so I wouldn't dare offering a tutorial about something I don't feel like I'm mastering. However if you have a little knowledge in scripting (in general), you should deal with them quite easily.
Thanks again for your words...
Guillaume
kjones9999
#36 Posted : Saturday, March 31, 2018 12:38:43 AM(UTC)
kjones9999
Hi Guillaume - I have been doing player cards with info and images in a spreadsheet for each person on a 30 man roster. The button changes the title and activates the overlay. It is GREAT!!
Is there an automated way to make buttons, or a list using the data sources? It takes a significant amount of time to create each button. Would be great if it could be auto-generate buttons from the data source itself.
#37 Posted : Saturday, March 31, 2018 2:03:38 AM(UTC)
Hey Charles!
Not sure to fully understand but here's what I do :
create a vMix datasources with the xaml title (player card)
Then create 2 buttons for next and previous row
Or create a single button to start the looping mode on datasource
Check this video I did using this and tell me if that's what your talking about
Bien à toi
Guillaume
PS : to make this work I had to add functions to vMixUTC. I can share, no problem...
kjones9999
#38 Posted : Monday, April 2, 2018 6:49:42 PM(UTC)
kjones9999
Its close -- I need to be able to bring up a title card within 2-3 seconds of a good play -- and it seems that buttons are the best way to do that --- and it works great with UTC- BUT it is time consuming writing the sheet and row number to 70-80 buttons. Would be great if buttons could be automatically generated based on rows....
Siroki
#39 Posted : Friday, June 29, 2018 9:25:17 AM(UTC)
Siroki
Bosnia and Herzegovina
Was thanked: 27 time(s) in 24 post(s)
DWAM wrote:
Hey Charles!
Bien à toi
Guillaume
I have 18 players for match (26-27 inputs of players) so for me its quite not neccesseary to make 27 inputs and use them for presenting players with name, number and picture. Can this be done in this way:
- I make .jpg files for every player like this:
- Put pictures in one folder on desktop
- Make xaml title that contains only image source
- In UTC make list widget with image sources (if this can be done, if list can pull image path)
- And in the end on presentation before match just choose players from the list which are playing one by one to go out on screen
Is this possible?
Thank you
Best regards
#40 Posted : Friday, June 29, 2018 12:43:59 PM(UTC)
Hi Siroki
I'd say it's possible yes. I wouldn't do it this way, but it can work.
I believe the datasource way is easier as it will provide you with buttons to move between records or use auto next
Guillaume
5 Pages<1234>»
