66 Pages«<2324252627>»
#481 Posted : Friday, February 16, 2018 4:50:49 AM(UTC)
I tried to open NDI Monitor, but it crashes all the time...
Before you use NDI in UTC, make sure to get it working on this host. You can also try with OBS
You did not answered clearly my 1st question :
Are you using UTC on the same host as vMix?
Does it conform to Newtek's specs for NDI?
Joeboe
#482 Posted : Friday, February 16, 2018 7:24:13 AM(UTC)
Joeboe
Yes, I tried it on the Host PC, and a different PC and I get the same results on both setups, and they both conform to to Newtek's specs.
UPDATE: Now I got NDI monitor to work on the other PC, but UTC still does not show the video....the 2 PCs see each other, but no luck with getting the video to work on UTC on either of them.....
chococrispis35
#483 Posted : Saturday, February 17, 2018 5:29:09 PM(UTC)
chococrispis35
Elgarf, other request:
In the color selection of the widgets, can you have more variety of colors or selection of palette for the desired color?
desmar
#484 Posted : Sunday, February 25, 2018 11:21:56 PM(UTC)
desmar
Canada
@elgarf
Had someone ask if it would be able to have custom scores to score widget,
Were user could define custom scores up to 6 different.
User could enter values in 6 different values and then when score widget
would add whatever the user had entered.
eg. +3, +8, +10, +14, +22, +29
elgarf
#485 Posted : Monday, February 26, 2018 1:08:49 AM(UTC)
elgarf
Russian Federation
Was thanked: 231 time(s) in 130 post(s)
@Joeboe, I've tested UTC NDI monitor on the fresh windows install, and it worked ok =( I'll look what else I can do
@chococrisps35, I think that's not very hard.
@desmar, looks like I need make custom scoreboard widget =)
desmar
#486 Posted : Monday, February 26, 2018 1:32:35 AM(UTC)
desmar
Canada
@elgarf
Bug perhaps
Keypress command not working in button widget... in latest build
elgarf
#487 Posted : Monday, February 26, 2018 3:23:26 AM(UTC)
elgarf
Russian Federation
@desmar, check keypress command from web browser, please:
http://127.0.0.1:8088/api?Function=KeyPress&Value=A
#488 Posted : Monday, February 26, 2018 7:30:48 AM(UTC)
Just use scripts within a button widget. 9 points is 3 times 3 points for instance
desmar
#489 Posted : Monday, February 26, 2018 2:00:13 PM(UTC)
desmar
Canada
Works from Web Controller and (not web browser or vMix UTC) tried with 3 browsers,
must be a bug in vMix.
And as per Martin...
A does not work through the WebAPI, but you can use any other keyboard button.
desmar
#490 Posted : Monday, February 26, 2018 2:08:37 PM(UTC)
desmar
Canada
Problem is that it does not display properly, due to delays, you can see it add +3 then +3 then +3 in score and not as +9.
chococrispis35
#491 Posted : Tuesday, March 13, 2018 2:08:03 PM(UTC)
chococrispis35
help me
How can I enter an xml file locally (xml file saved on my hard drive) to get the data in the external data widget?
Some explanation ?
Joeboe
#492 Posted : Tuesday, March 13, 2018 11:14:37 PM(UTC)
Joeboe
Still can not get video on the NDI monitor
#493 Posted : Wednesday, March 14, 2018 4:35:19 AM(UTC)
@Desmar
Yes it does, but you might experience issues with some keys when not working with a QWERTY keyboard.
Apparently, UTC does not recognize the keyboard type. I noticed this since the very beginning of UTC.
If you try with the letter T for example, which is common to QWERTY or AZERTY, you will see it works.
@Elgarf
Can you do something about this? Check the keyboard type...
Guillaume
#494 Posted : Wednesday, March 14, 2018 4:46:55 AM(UTC)
@Desmar
Yes it does, I just tried but you might not be using what I suggested.
- Create a score widget
> in Hotkeys, tick the +3 box and in the corresponding Link area give it a name, i.e. +3
> map it to your XAML title as usual
- Now create a Button widget, call it +9
> add a script, select command "ExecLink" and write down +3 in the Link area
> add a second script, select command "ExecLink" and write down +3 in the Link area
> add a third script, select command "ExecLink" and write down +3 in the Link area
Now when you press this +9 Button Widget, the ExecLink +3 is executed 3 times to the Score Widget, adding 9 points to your title.
I just tried, it works perfectly, no delay, no latency and my UTC is remote to vMix.
Guillaume
#495 Posted : Wednesday, March 14, 2018 4:55:37 AM(UTC)
Using the XML data dll provided by Elgarf
Using the correct path to your XML file in the External Data Widget
Guillaume
#496 Posted : Wednesday, March 14, 2018 4:58:37 AM(UTC)
Latest UTC release greatly improved the NDI monitor feature. It works great now.
If it doesn't for you it's most likely due to your system and the way NDI is installed.
Uninstall everything that's related to NDI on this host and start over.
Guillaume
elgarf
#497 Posted : Thursday, March 15, 2018 5:35:09 AM(UTC)
elgarf
Russian Federation
@desmar, there is another way to add score by some scripting.
Here
Code:
_('Inputs[{0}].Elements[0].Text')
- address to element 0, here it is "Headline".
I need multiply value to 1 to convert text to decimal.
Then +3 adds 3 point to the score.
elgarf attached the following image(s):
JAIRODJ
#498 Posted : Thursday, March 15, 2018 10:48:32 AM(UTC)
JAIRODJ
Was thanked: 16 time(s) in 12 post(s)
Hi good day.
Please could you help me and tell me how to separate or remove texts from the chain.
I used the expression
_ ('Inputs [78520042-b6df-4aac-8c17-d3d7f056c24b] .Title')
to obtain the title of the entry and the result is:
List - Andru Donalds - Mishale.mp4,
Now how can I do to remove "List -" and ".mp4"
and get only the title "Andru Donalds - Mishale"
Apologies I am not a user who knows script and it complicates my use, but I learn fast.
chococrispis35
#499 Posted : Thursday, March 15, 2018 12:48:20 PM(UTC)
chococrispis35
My UTC Baseball Project - 14/03/2018
tkachuk.alex
#500 Posted : Thursday, March 15, 2018 5:07:51 PM(UTC)
tkachuk.alex
Ukraine
Nice! How do you edit that on +1 coloring red dots? I use for every dot list with "red" and "empty", and it's little hard
Guest (37)
