Adriankey4
#1 Posted : Saturday, June 29, 2013 4:54:11 PM(UTC)
Adriankey4
Jamaica
Hi
I am streaming a church service tomorrow and i want mix with one and stream with the other. How can i do that?
Tell me before 5pm Jamaica Time PLEASE!!!!!!!!!!!!!!
Egriswold
#2 Posted : Saturday, June 29, 2013 5:36:53 PM(UTC)
Egriswold
Was thanked: 35 time(s) in 34 post(s)
If your laptop is powerful enough to run vMix then you should be able to stream from it too.
but not knowing the total picture it's hard to advise you on the best way.
thanks 1 user thanked Egriswold for this useful post.
Adriankey4 on 6/29/2013(UTC)
macjaeger
#3 Posted : Saturday, June 29, 2013 7:39:50 PM(UTC)
macjaeger
Just so you know: a LANC cable is used to remote control cameras, you probably mean a LAN cable. Yet i don't think what you have in mind is a good idea: in order to send vmix's output to the other laptop you have to encode the video anyways, so why not just do the encode for streaming on the same machine vMix is running?
h2video.nl
#4 Posted : Sunday, June 30, 2013 7:10:52 AM(UTC)
h2video.nl
if your computernis powerfull enough it should work on one comuter. however, i sometimes split into two computers aswell to seperate mixing and recording and streaming. in this way i can also use different titles and banners etc.
i use a bm card or shuttle as an output and input this in the streaming computer. thus you can control everything and seperate.
using a lan cable is possible if you run the vmix supplied desktop capturing program and capture in the second screen. i would not recommend this! i sometimes use this option as a quick and low end way to capture a camera or webcam connected to a second computer or laptop and capture the output as a desktop capture. p.e. i do this to connect an extreme viewpoint, from the top of thevceiling or far away in the other end of a stage. the quality of the image and framerate is not so important.
for livestreaming just try your luck with one computer and reduce quality and resolution when you reach maximum capacity.
good luck...
stfan
