Argo82
#1 Posted : Wednesday, February 14, 2018 12:33:21 PM(UTC)
Argo82
Was thanked: 7 time(s) in 5 post(s)
Hi Everyone,
I don't know if this is common knowledge now, but I did find a few messages concerning this.
For those having issues with toggle shortcuts on MIDI controllers, here is how I got mine to work.
I bought a used Novation Launchpad S and tried to setup shortcuts and activators. I found that when I set a toggle shortcut (e.g.,"OverlayInput1") the effect would activate and deactivate as soon as I let go of the button.
When you setup your shortcut, check the box next to "Value" for the MIDI note. Fairly simple solution, however I didn't think to do this right away. I didn't think I had to do this with my Behringer X-Touch Mini, so it may work differently for controllers.
Argo82 attached the following image(s):
midi - toggle.png (13kb) downloaded 7 time(s).
thanks 2 users thanked Argo82 for this useful post.
IceStream on 2/14/2018(UTC), sinc747 on 2/14/2018(UTC)
geofhill
#2 Posted : Saturday, June 2, 2018 12:24:23 PM(UTC)
geofhill
I'm having issues with activators on x-touch. I can activate button lights on the individual channels with faders but the rest of the controller lights do not activate. Function keys, modify, automation, utility and all other keys don't activate no matter which controller I choose in the dropdown list. Very frustrating that half the controller will activate but not the other half.
What did you do to solve this issue on yours?
