2 Pages<12
Barney Box Lane
#21 Posted : Sunday, February 11, 2018 11:10:33 AM(UTC)
Barney Box Lane
pm wrote:
I did some try and error to get it working. And I had a hit...
As soon as I disable IPV6 on the network adapter, .52/.53 are announcing their NDI sources.
I have only one client available for testing now. Could someone with the same problem test it?
Probably it's not the right solution yet, but it could give a hint to Martin what the underlying problem is.
Patrick
Hi Patrick,
I have two computers of the same spec that have stopped announcing NDI since .53
how do you disable IPV6?
thank you
MrKrotos
#22 Posted : Sunday, February 11, 2018 11:12:46 AM(UTC)
MrKrotos
I had to resolve to issue on a clients machine quick so its running an older version again, I will spin up a spare boc and try the IPv6 workaround.
I need the latest version to fix the facebook API issues with social anyways, brb :)
rudyengels
#23 Posted : Sunday, February 11, 2018 11:14:58 AM(UTC)
rudyengels
Was thanked: 25 time(s) in 18 post(s)
Control Panel > Network and Sharing Centre > Change Adapter Settings
Right-click Ethernet > Properties > Untick Internet Protocol Version 6 (TCP/IPv6)
MrKrotos
#24 Posted : Sunday, February 11, 2018 6:45:55 PM(UTC)
MrKrotos
I have tested .53 on a few machines now and disabling IP v6 does seem to help, I also noticed on a couple of machines that after fixing it, you can re-enable IP v6 again and it didnt seem to create further issues.
Machines running a mix of Windows 7 & 10 (all x64) on intel CPUs and 8 or 16GB RAM
MrKrotos
#25 Posted : Sunday, February 11, 2018 6:49:23 PM(UTC)
MrKrotos
Just for developers ref, I always tune my machines with no powersave (including the devices) so thats nothing to do with it.
I have a mix of NICs on my test machines, that didnt seem to make any difference.
Turning off IP v6 did though, re-enabling it after didnt create the same issue.
Standard DHCP here via house router, only tweak is using Gogle DNS on 8.8.8.8 & 8.8.4.4 for IPv4
pm
#26 Posted : Sunday, February 11, 2018 7:34:30 PM(UTC)
pm
Was thanked: 33 time(s) in 28 post(s)
Re-enabling IPv6 doesn't work on my machine, the issue appears again.
#27 Posted : Monday, February 12, 2018 6:05:07 AM(UTC)
Was thanked: 4735 time(s) in 1624 post(s)
NewTek have provided us with what we hope is a permanent fix to the recent discovery issues.
Before releasing a full vMix update, here is an updated NDI DLL you can test first if possible:
https://www.vmix.com/download/NDIFix352.zip
Install instructions:
1. Close vMix
2. Extract the DLL from the zip file
3. Copy this DLL file into the C:\Program Files (x86)\vMix\NDI\x64 folder overwriting the existing copy.
After the problem is confirmed resolved we will release an official vMix update.
Thanks!
avsoundguy on 2/12/2018(UTC), sinc747 on 2/12/2018(UTC)
pm
#28 Posted : Monday, February 12, 2018 7:36:43 AM(UTC)
pm
Hi Martin
On my test client, the new version of the dll is working and the NDI sources form .53 are announced again.
My other computers are on production now, so no chance to test it on different clients.
Let's see what the feedback of the other testers is.
Patrick
rudyengels
#29 Posted : Monday, February 12, 2018 7:59:01 AM(UTC)
rudyengels
I can confirm this works, Martin. Even with IPv6 enabled
IrvinCee
#30 Posted : Monday, February 12, 2018 12:37:20 PM(UTC)
IrvinCee
Just tested it and confirm too that the fix works.
Had the issue on 3 machines.
avsoundguy
#31 Posted : Monday, February 12, 2018 12:59:28 PM(UTC)
avsoundguy
The new dll fixed the issues I was experiencing using Martin Kay's NDI No-Audio Meter, it works perfectly now, thanks
sinc747
#32 Posted : Monday, February 12, 2018 3:42:10 PM(UTC)
sinc747
Was thanked: 204 time(s) in 170 post(s)
Worked for me, too.
Well done, Martin!
- Tom
Barney Box Lane
#33 Posted : Monday, February 12, 2018 5:56:11 PM(UTC)
Barney Box Lane
all good and worked for me too, two Asus rigs same spec, thank you for the quick fix Martin
AlanZ
#34 Posted : Monday, February 12, 2018 6:28:39 PM(UTC)
AlanZ
It appears to be working for me too
#35 Posted : Monday, February 12, 2018 9:23:29 PM(UTC)
Thanks everyone for testing, we have now posted 20.55 with this fix.
sinc747 on 2/13/2018(UTC)
2 Pages<12
