Instant Replay
can I replay the output?
my vmix is 4k version so that it only get 1 camera instant replay. can I just add the output into instant replay? if so I can delay the event live stream for more than 120 seconds I tried select Output 1 ,but it turn out be black screen Does anyone know how to do? bh1054010 attached the following image(s):  微信截图_20180112163848.png (91kb) downloaded 2 time(s). 微信截图_20180112164107.png (674kb) downloaded 0 time(s).You cannot view/download attachments. Try to login or register.
Have you tried Video Delay?
Add Input / Video Delay
30 seconds is the maximum I believe.
@ bh1054010
Did you start the Instant Replay Recording and Playback? Also, what is your purpose? This can work in short bursts, but will become a loop as soon as you catch up to your start time. If desiring a permanent or perpetual delay, you would be best to send a secondary External Output of the delayed Replay playback via NDI to another vMix PC for External delivery.
Joined: 8/3/2015(UTC) Posts: 325 Location: Chicago, IL
I exclusively record my output to use as my replay feed. I have never had an issue.
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
yes you can assign output 1 to be your replay recording.
black screen - hit record and make sure the word LIVE is highlighted red.
you can't delay it and play it out using the replay as the replay will become your output. if you meant delaying it the normal way I don't think you can delay by that much and I think it takes up around 5mb of ram for every second if I remember right so you want to avoid if possible.
Instant Replay
